Old 02-05-2008, 06:10 PM   #11
shadygrady's Avatar
shadygrady will become famous soon enoughshadygrady will become famous soon enough
Yeah,I was thinking about that today at work.No power to the actuator menas it`s` gotta be something else.Honestly when I checked it I got some wierd readings.At first I had about 12 volts,then I couldnt seem to get it to read anything after that.When my 4 wheel drive was working the indicator lights on the floor shifter,thats shaped like a truck and has the axels/wheels light up,they worked.when it quit working,the lights quit working.I`m not familiar with the ball switch you`re talking about.I`ll look for it when I get some time.I changed hydrolic hoses on a drilling rig all day and dont feel like working on nothing else today.Thanks.Should I check for 12 volts at the 4x4 fuse which is good and make sure I got power there?
1989 k1500 Cheyene 4x4,regular cab,swb,4.3 V-6.11`x 4`k&N Open element,TBI mods,smog pump delete,mechanical fan clutch to electric fan swap.flowmaster 2.5 dual exhaust.
shadygrady is offline   Reply With Quote
Old 02-05-2008, 10:43 PM   #12
stumpuller454's Avatar
yeah would`t hurt, if ball switch is bad won`t light up 4x4 light or engage actuator,
Old 02-19-2008, 04:44 PM   #13
shadygrady's Avatar
stumppuller,I found one plug on top of the actuall transfer case and one kinda on the side back towards the tailshaft.I`m new to 4x4 so this is new to me.The one on top feels like only a 3/4 or so.Not sure if I`m even looking in the right place.I gotta pic up a hanes/chilton manual when I get a chance.I know its been a little while since my original post but work keeps me busy and my wife and my iroc usually get my attention before my truck does.thanks.
Old 02-19-2008, 06:16 PM   #14
ball switch is directley up from the shift-arm lf side. the one on the back is a speed sensor,
Old 03-05-2008, 07:43 PM   #15
Pull the plug off the switch and jump the connection, this should give you voltage at the actuator, If the ball switch is acting up splice in a rocker switch across the 2 wires and mount in on the side of the floor shifter, then flip the switch when you put it in 4 wheel. If its the actuator make sure its an exact match.
Old 03-06-2008, 05:45 PM   #16
shadygrady's Avatar
Been working too much lately to mess with it.Get to it soon I hope.
Old 03-18-2008, 04:47 PM   #17
shadygrady's Avatar
OK I pulled the ball switchout,unplugged it and plugged it back up a few times,then I pushed it in and waitedfor a while.Actuator never moved.Goint to try to get 12 volts at the ballswitch now.I had my son shift it into four wheel drive for me while I watched the actuator and held in the ballswitch,still nothing.
I`m no mechanic,not exactly sure what you mean
Old 03-18-2008, 05:07 PM   #18
shadygrady's Avatar
Oh ****.I couldnt get 12 volts at the check ball so I put a known working battery in it and tried to get 12 volts at the battery in the truck.COULDNT GET IT THERE EITHER.Guess I`ll have to get another.feel a little dumb now.
Man you cant say C R A P on here.
Old 03-19-2008, 07:49 AM   #19
Ill try again, pull the connector off the ball switch, check for power ( KEY ON OF COURSE!), If no power the problem is upstream, (fuse broken wire, pinched wire, grounded wire,) If power is present, use a small piece of wire jump the wires inside of the connector, leave it, go to the actuator connector check to see it there is power. if there is plug the actuator in while out of the differential, it should expand, if it doesn't its bad, if it does put some pressure on it to make sure its not weak. I had a problem with a 91, the linkage was wore so I used the rocker switch, as a jumper for the ball switch for manual engagement. good luck
Old 04-19-2008, 03:51 PM   #20
shadygrady's Avatar
Ok,I got a new voltmeter.I did get 12 volts to the actuator and at the fuse.Fuse is good.I could not get 12 volts at the ball switch.So far no luck finding a bad wire.Any other suggestions.Thanks
Actuator for tranfer case Hayden Chevy Truck Forum 13 10-12-2007 08:21 PM
Floor Heater Actuator Brazzy Chevy Truck Forum 5 05-22-2007 11:48 AM
4X Actuator? 1988MonsterChev Chevy Truck Forum 3 12-14-2006 06:54 AM
1997 4x4 Actuator Service TROTH Chevy Truck Forum 2 03-12-2006 03:25 PM
1994 Chevy Truck - Automatic Transmission Rusty Scupper Chevy Truck Forum 4 12-15-2005 11:33 AM
