| | #21 |
| (92 chevy 350 no start) This how he listed it. Hey guys JR. Keith, 75K30, Skylark and others this member needs help see what you can do for him please. Thanks! GMC |
| | #22 |
| before pulling the trans switch check for power at the wire harness going to it key on if no power check for an open between the fuse and the tranny switch. |
| | #23 |
| You can buy a manual cable actuator. It about $40. |
| | #24 |
| Junior Member Join Date: Oct 2008 Location: louisiana
| where can you get this manual cable actuator for 40 bucks. the only one i have found is at lmc and it is 300.00. thanks |
| | #25 |
| | #26 |
| Full Member Join Date: Feb 2009 Location: Okauchee, WI
| Sorry to bust in on an old thread, but I'm having the same problem. I was going to wire in a rocker switch, but the origonal switch on the tcase is a three wire. Which wires do I install the rocker switch on? I just replaced the tcase, and the new one has the two wire swich on it. The two wire and tthree wire switches are different length so they are not interchangeable. 94 chevy z71 350, 4l60, np241c.Thanks....Matt |
| | #27 |
| Full Member Join Date: Feb 2009 Location: WI
| ok the quickest way to handle this is put the truck in 4x4 high and climb under neith it grab the frunt drive shaft try to turn it. if it turns its your transfer case. if it dont then go to your actuator. pull it out hook it to a jump box it will take a bit if it moves. if it dont move at all then its the actuator. if it dose its wireing |
| | #28 | |
welcome to the forum anyhow id the wires that lead to the actuator and splice it in
__________________ 4 wheels move the body 2 wheels move the soul B.W.A.I | |
| | #29 |
| Welcome to the forum mtsnieg, hope to see your update. May want to read this other thread: 4x4 engauges but wont turn front wheels |
| | #30 |
| They make a cable setup that replaces your front actuator. Its very reliable and will not fail you.
__________________ Everyone hes to believe in something, I believe I will go ride my motorcycle. MSF certified Ridercoach USMC 92-96 USCG 98 to present |
| Actuator for tranfer case | Hayden | Chevy Truck Forum | 13 | 10-12-2007 08:21 PM |
| Floor Heater Actuator | Brazzy | Chevy Truck Forum | 5 | 05-22-2007 11:48 AM |
| 4X Actuator? | 1988MonsterChev | Chevy Truck Forum | 3 | 12-14-2006 06:54 AM |
| 1997 4x4 Actuator Service | TROTH | Chevy Truck Forum | 2 | 03-12-2006 03:25 PM |
| 1994 Chevy Truck - Automatic Transmission | Rusty Scupper | Chevy Truck Forum | 4 | 12-15-2005 11:33 AM |
