| Full Member Join Date: Mar 2007
| I just found a body that is a 2 wheel drive truck. 1981 model chevy shortbed. I have a 1983 chevy 4x4 with bad body, am going to replace entire 4x4 body with the 2 wheel drive body. my question is will i have to raise body of 2wheel drive cab for clearance i know i will have to cut hole for shifter, any help would be appreciated thankx frank3ks |
| If you are doing a body swap, than by all means go for it. There is not a difference between a 2wd and 4wd body, and it will bolt right up. The transmission tunnel is the only thing that has to be modified for the shifter(s). and this is terribly easy. You should have no troubles with your swap. |
| Thankx so much didnt think any difference even heard floor pan is outlined for 4x4 cut out thankx again for reasureing me. |
| | #4 | |
__________________ Friends dont let friends use body lifts USMC 92-96 USCG 98 to present | |
| The tunnel does have to be cut, but the 4wd tunnel will bolt on the other cab. The body has lines from the factory to show where it needs to be cut. Simply remove the 2wd tunnel, and bolt up the one from the 4wd truck. Should be as simple as it comes. |
| some floors were cactually bolt in, Some were solid.
| four wheel drive problems | ddraszt | GMC Truck Forum | 8 | 12-17-2007 08:42 AM |
| Wheel Question on my 4 wheel drive??????????????? | 92BlueZ71 | Chevy Truck Forum | 4 | 03-19-2007 05:06 PM |
| 4 Wheel Drive Help? | 97Z71 | Chevy Truck Forum | 5 | 03-04-2007 08:32 PM |
| Four wheel drive question... | gunner1 | Chevy Truck Forum | 12 | 02-05-2007 02:45 PM |
| 4 wheel drive | 92BlueZ71 | Chevy Truck Forum | 1 | 03-06-2006 11:37 AM |
