Old 10-08-2008, 08:43 AM   #1
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
Transfer case noise
Ok here goes one of the minor problems I have with my truck is the transfer case making noise in 2hi. Sounds almost like gears are grinding once in awhile. In order for me to drive it I have my front driveshaft off, front axle actuater disconnected and my selector in 4 hi. It doesn't bother me because since I moved south ( got out of the snowbelt) I haven't needed 4 wheel drive. Other than replacing the transfer case, is there rebiuld kits out there at a reasonable cost.
Kennyray is offline   Reply With Quote
Old 10-08-2008, 11:40 AM   #2
my83432 is on a distinguished road
I think I know this one. It's a 241c case right. There is snap ring that holds the rear output shaft in place, it broke. To test this pull the rear drive shaft. Then grab the output shaft and push it in and out. It should not move. If it does remove the tail housing and look for the peices of the snap ring. You can just replace the ring but the grinding that you hear is a brass ring that engages the 4wd. Since brass will not stick to a magnet it is hard to get it out of the case. Those peices of metal will shorten the life of the case.
my83432 is offline   Reply With Quote
Old 10-08-2008, 11:48 AM   #3
Kennyray's Avatar
Thanks, I'll check it out the next time I get a chance, and your right, it is a 241c. Wiil post back with results when I can get to it.
Old 10-18-2008, 06:12 PM   #4
fritztesi is on a distinguished road
transfer case makes noise when i 2high only
what part # can fix this an how much and where can i find the partand a repair manual that shows the tear down .any responce will help
fritztesi is offline   Reply With Quote
'01 Gmc Transfer Case GM For Life GMC Truck Forum 10 03-10-2009 02:38 PM
'98 Transfer case mont91 Chevy Truck Forum 3 05-22-2007 12:10 PM
GM Transfer Case jeepers06 Truck Classifieds 1 09-02-2006 11:07 PM
Transfer Case flossy2259 Dodge Truck Forum 0 08-08-2006 05:00 PM
transfer case guidorr73 Dodge Truck Forum 2 12-12-2005 06:39 AM
