Old 11-08-2008, 04:03 PM   #1
yathnk's Avatar
yathnk is on a distinguished road
Replacing front wheel joints
My front wheel joints are starting to make some noise. Does anyone know if you have to remove the hub bearing or can you remove the whole assembly to get to the wheel joints on a 2001 Dodge 4wd?
yathnk is offline   Reply With Quote
Old 11-08-2008, 09:34 PM   #2
Moderator
am assuming you are referring to the ball joints?? no, you should not have to remove any of the hub assembly to replace those. just remember the jack stand underneath the lower a arm so that you dont get that coil spring in your face when you pop that joint loose.
Old 11-08-2008, 09:48 PM   #3
mod-o-tator
well, it's in the 4by section so i was thinking CV joints?
member map add yourself
alldatadiy
Old 11-09-2008, 05:53 AM   #4
Moderator
maybe youre right. cv joints i cannot say for a dodge. i know on a chevy, you can turn the wheel hard and be able to fenagal them out. im sure they are the same way on your yours.
Old 11-09-2008, 09:53 AM   #5
yathnk's Avatar
Thanks guys, but actually the front wheel joints on a 01' Dodge 4WD are just like the U-joints on your drive shaft. The 01' has a solid front axle with joints at the end to allow the wheels to turn left or right.
Old 11-09-2008, 10:37 AM   #6
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
here isa pics sorry so small, i`ll try to fix....
Red seal certified Journeyman Automotive Mechanic
Supercharger comming soon!
Old 11-09-2008, 04:18 PM   #7
yathnk's Avatar
Thanks for the pic
Hey thanks for the pic and the advice, I will try it again next week on my next days off and let you know how it went. Thanks again
Old 11-11-2008, 01:50 PM   #8
foxdodgeman1998 is on a distinguished road
you have to remove the hole assymbly with axle and all did one on a 1998 dodge ram 1500 4x4. the hub nut is on there very tight gonna need a breaker bar and probbly a cheater bar we tried an impact and it wouldnt budge it. becareful when you reassemble it not to hit the axle seal inside the axle housing.
foxdodgeman1998 is offline   Reply With Quote
Front End Noise. Wheel Bearing? RobK Chevy Truck Forum 1 05-11-2008 12:48 PM
Front Wheel Bearing TZR2 Chevy Truck Forum 23 09-21-2007 11:18 AM
'02 1500 (4x4) front wheel bearing? regulator1 Dodge Truck Forum 1 08-26-2007 06:21 AM
front wheel noise jasonv100 Chevy Truck Forum 5 06-20-2007 10:59 PM
can not remove front wheel hubs rcs34 Dodge Truck Forum 1 01-31-2007 07:30 PM
