Old 12-04-2008, 05:40 PM   #11
72'CaminoKid's Avatar
hmmmm. i'm not sure of the physics of this, with the back weighing significantly less, it will somehow affect the ride quality with add a leafs back there. just not sure if it would make it much worse, or possibly not much more noticeable than it is now. i'm thinking that the lack of weight in the back will make it harder to compress the springs so you'll feel the bumps alot more. but honestly, not sure. i just no on my buddies jeep with AAL's it was terrible riding in that thing
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 12-04-2008, 05:43 PM   #12
for the $100 air is more versitile, and will lift it load assist maintain the present height and help when loading
Old 12-04-2008, 06:13 PM   #13
see error's Avatar
see error has a spectacular aura aboutsee error has a spectacular aura about
superlift has 2 one is 1-2 inch one is 2 1/2 inch check out summit about $85
2004 gmc 1500 cc 4x4
see error is offline   Reply With Quote
Old 12-04-2008, 06:49 PM   #14
76silverado's Avatar
76silverado has a spectacular aura about76silverado has a spectacular aura about
I was lookin at those, I might go that route, keep the info comin!
http://s513.photobucket.com/albums/t...t=HPIM1105.jpg
'76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL!
76silverado is offline   Reply With Quote
Old 12-05-2008, 10:51 AM   #15
the add a leafs in mine rock the teeth out of your head. they arent bad but i do notice that they are there. the only great thing i can say about them is i can put 3000lbs in mine and it not sag like everyone elses 1/2 ton.
Old 12-05-2008, 01:00 PM   #16
3k would put mine to the bump stops. i did notice my load assist shocks deformed. not sure if it was due to the load of scrap or my exhaust. i'll get a pic next time i have it on the hoist.
Old 12-05-2008, 06:38 PM   #17
Your 4x4 already has a block in the back. What is the size of this block? If you have a 2 inch blok you can easily install a slightly larger block in the back to achieve the desired ride heigth. The factory used anywhere from 1 to 4 inch blocks in the back so finding the correct one would be easy to do.
Salvage yards are full of them and you can get them cheap. You will drop about 40 bucks for new u-bolts though.
This will provide you with the same ride you have now. You dont want to add anything taht will hinder your suspension performance.
Shackle flips are an option as well, and then you can eliminate the block in the rear and still gain some lift.
Lots of low dollar options here.
Old 12-05-2008, 08:24 PM   #18
how bout blocks never even crossed my mind
99 suburban xlt
96 silverado
Leaf Spring Question 84ChevyK10 Chevy Truck Forum 8 11-16-2008 08:45 PM
add a leaf questions chevy_man99 Chevy Truck Forum 16 06-06-2008 05:58 PM
update on squeaking leaf springs classicZ71 GMC Truck Forum 9 05-01-2008 05:18 AM
Annoying leaf springs classicZ71 GMC Truck Forum 2 03-24-2008 04:35 AM
94 ranger rear leaf springs lmm3466 Ford Truck Forum 0 07-13-2006 05:52 PM
