| Senior Member Join Date: Jul 2008 Location: Poco BC
| Noise when engaging 4Lo? So I find now that I have my first 4X4 truck, it is a 1996 K2500 4L80E tranny, with the three push buttons on the dash to put it into 2Hi or of course 4Hi or 4Lo, anyway I would say when doing it like I do, which is sitting still in neutral that between 2hi and 4hi it is fairly quiet when putting it back into gear from neutral, but when I push 4Lo and then put it into gear it seems to clunk I guess you would call it, and most definetly seems to want to go, lots of torque it feels like, is this normal that it is engaging a little harsher than the other two settings? |
| depends on how loud the clunk is i guess. never owned push button and don't ever plan to either.
| normal, mine is push button, even engageing while slowly moving (into high) there is a clunk, wouldn`t worry about it untill the chain skips or a really bad bearing noise while moving, or indication of metal during oil flush.... good to go.
| Thanks for the responses, now that leads to another question, I was told by the salesman I can shift on the fly from 2hi to 4hi or back, but need to be stopped and in neutral to engage 4 lo, is this right? I never got a manual for it, and want to find one, but untill then maybe I can get most answers here on how to use the four wheel drive system. |
| Senior Member Join Date: Jan 2009
| It shouldn't be a problem. I had a 93 Jimmy with push button 4wd that made the same noise. I even changed the actuator motor after it went out & both motors made the same noise. If you're still worried, changing the fluid might help. |
| | #6 | |
yeah thats the way its supposed to work, but i can always hear a clunk when engaging it, if i can i will stop and engage it first, just to be nice to it.
__________________ SUPERCHARGED 454 K2500 GMC! 450hp and 600ft/lbs http://www.youtube.com/watch?v=WJ27RJHfJKE "sailing with Captain Morgan often!" | |
| yes, you can switch between 4hi 2hi while on the move |
| Senior Member Join Date: Nov 2008 Location: upstate S.C.
| yea i once hit the button in my 98 doin 60 down the highway, it engaged fine, drove it 100,000 more miles without a problem. this was by accident by the way. mine also had the clunk sound whrn engaging 4 lo |
| Full Member Join Date: Sep 2008
| we have a 08 f150 and it makes the clunk as well into 4lo and its brand new its just what they do |
| Normal... no need to be alarmed. It's the synchros engaging and the output shaft drive drum sudden increase in RPM... |
| Transfer Case not engaging | rdhack | Chevy Truck Forum | 8 | 12-13-2008 05:48 PM |
| AC compressor not engaging | cplnorton | Chevy Truck Forum | 2 | 06-05-2008 06:02 AM |
| 4wd not engaging...Please help | bstewar77 | Dodge Truck Forum | 13 | 07-25-2007 04:51 PM |
| Please Help!!! Problems engaging 4WD | sierra 4x4 | GMC Truck Forum | 8 | 10-09-2005 11:27 PM |
