| Junior Member Join Date: Apr 2009
| what tire pressure on 12.5 x 35's Hello guys, I am new to this forum today. Already picking up some tips. My son has a 1979 f-150 that we rebuilt frame up last year. 472 engine, c6(rebuilt ourselves) 4.56 gears, 35'' Thornbirds. I have been searching for a couple of hours and haven't found a thread that specifically adresses tire pressure on this setup with these tires. The truck weighs 5400# and is used mainly on the street. The max tire pressure is I think 34 but we have been running 20. Lots of rolling resistance! How much should we run or haw much CAN we run without severly affecting wear? Thanks in advance. |
| Senior Member Join Date: Mar 2009 Location: South Jersey
| Not sure if this will help, my company did a worldwide safety warning on tire pressure. Can't find the site we used, but this link i'll add can help a little... Tire Tech Information - Air Pressure - Correct, Underinflated and Overinflated Petersons 4 wheel drive did a great article on large tire pressure for off road trucks. Try there off road forum. << link removed by mod >> Last edited by bradrhale; 04-21-2009 at 06:29 AM. Reason: no related forum advertising allowed |
| Welcome and howdy from TEXAS I hope you hang around for a long time we all have ton's of fun here. I running 40psi on my 31" tires if I was you I would run more. |
| Thanks chickenbone and gmc. I was kind of hoping someone would say more. GMC; how wide are your tires? I kind of think width would make more difference than height? |
| I've got 18 inch on my F-250 and most of my other large trucks run 10r22.5 I also own a 89International that i use to move my lowboy. I'll post a few pics. Real sharp ole Truck. Was my Brother-in-laws for years. He used to run Tators outa North Carolina. |
| I'm running 31x10.50R15 on a 10 inch wheels im speading the tires big times but I like my wheels. |
| Senior Member Join Date: Apr 2009 Location: Lorain
| I run 40psi and I got 33x12.50x16 Super Swamper SSR's. |
| havent seen alot of people use thornbirds as mainly street so difficult to give an exact measurement. if the max tire pressure advertises 34, than i might go with 30 or 32. |
| Senior Member Join Date: Jan 2009
| I'm pretty sure max tire pressure on those tires are 45 psi. You might double check on the sidewall. I had some Interco's that I ran 33 psi on the street. That was with an S15 Jimmy, so I would imagine a heavier vehicle like yours would enjoy about 38-40 psi. 20 psi would be better suited when you're offroad. |
| I've been away from the computer for a couple of days, glad to see all the responses! I'll check that rated pressure again and adjust the pressure upward. Thanks for all the help. |
| Tags |
| tire pressure, tires |
| Tire Pressure VS. Temperature | merlin5577 | General Truck Forum | 2 | 12-28-2008 04:17 PM |
| Tire air pressure. | gmctrucks | GMC Truck Forum | 5 | 12-18-2008 08:37 AM |
| 33's or 35's | duckkiller0010 | Chevy Truck Forum | 3 | 08-14-2007 12:48 PM |
| Tire Pressure? | Walleyes4me | Chevy Truck Forum | 2 | 08-03-2005 01:53 PM |
| Tire Pressure for snow driving | 99SD | Ford Truck Forum | 12 | 03-19-2005 07:31 PM |
