Old 05-02-2009, 08:52 PM   #11
harley9703's Avatar
harley9703 is on a distinguished road
and the maroon truck is 60's with 5:38 locked ront and rear i had 49's and broke every part in the rear axle.
never was saying it was built right. if anybody knows that I DO
harley9703 is offline   Reply With Quote
Old 05-02-2009, 10:05 PM   #12
72'CaminoKid's Avatar
you'll get more clearance with a 44. if more mud that anything, i'd say d44's with chromo shafts and what not... if theres gonna be a fair amt of traisla dn rocks where wheels will be binding up at odd angles, you may want the stronger axle ( but as 75 pointed out, not really too much of a strength difference) and with the d60 you lose your clearance. and width shouldnt be an issue, you can change the amount the tires stick out by the wheels your choose and some fender flares
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 05-03-2009, 12:05 AM   #13
Lonesome7.3's Avatar
Lonesome7.3 is a jewel in the roughLonesome7.3 is a jewel in the roughLonesome7.3 is a jewel in the roughLonesome7.3 is a jewel in the rough
I cannot see the photographs, is there another way to post them. I would love to see these trucks.
I got the **** lights off of an abandoned truck in Iraq.
Old 08-04-2009, 02:05 PM   #14
Bootzz is on a distinguished road
Originally Posted by harley9703 View Post
i have dana 60's in the front and rear the fit well under a full size. i would go with 60's if you plan on hammering it.
do what ya want if its built right with 39's you wont break even a 44
you get more ground clearance with a 44
what size tires are on the f150 in the top pic???
Bootzz is offline   Reply With Quote
Old 08-05-2009, 04:04 PM   #15
batty1214's Avatar
My friends all have chevy trucks....... 4 of them with 14 bolt rear, and dana44 front, and 3 of them with dana 60 front, and 14 bolt rear. they all have bb 454's in their rides, minus one, who has more money than sense, and got a 637 merlin for his.......... none have brokem axles, and theya ll run 40" or bigger....... They are the same width, so it's not going to stick out farther than the rear axle like you've been told, that is, if your pulling your axles off of a full sized truck. As for the strength, I don't think your 5.3 is going to throw enough power at a 44 to break it....... the dana 60 under that truck would just be kinda cool, cause you know that that axle is gonna get you through the pit, and home again....
Now, have you considered gearing? your 5.3 is going to be working fairly hard to push those 39" tires around......... you may want to decide what axle, based off of what your budget is... the d60 is a bit more costly to build up, or so I have found. the d44 is also much easier to find in a driverside differential.... unless you are changing out the transfercase, and swapping it to the pass. side drop
Old 08-05-2009, 05:43 PM   #16
chevyguy's Avatar
I got tired of replacing axles with 36s on my dana 44, so i went to the dana 60 in the front and never broke another axle. Spend the money and do it right.
USMC 92-96 USCG 98 to present
Old 08-07-2009, 01:22 PM   #17
hollonator's Avatar
hollonator is on a distinguished road
what do you all know about dana 80s?
hollonator is offline   Reply With Quote
Old 08-10-2009, 07:43 AM   #18
chevyguy's Avatar
Great axle for a read end.
Old 08-21-2009, 11:40 AM   #19
Chevysoldier77 is on a distinguished road
Sorry, don't get on here as much as I would like. I am going to spend the money and do it right. I'm going with the Dana 60 for the front and the rear. I like to play hard and I don't want to take a chance on breaking them. Plus eventually I'm hoping to go to bigger tires and lift.
I'm planning on going to 5.13 or 5.29 gears. Not sure about a new transfer case yet. Still looking at my options on that one.
Chevysoldier77 is offline   Reply With Quote
Early Bronco Dana 44 complete front end for sale Lonesome7.3 Truck Classifieds 9 03-11-2009 11:13 PM
Will Dana 44 knuckles work on a Dana 30? Lonesome7.3 4x4 trucks / off road 8 08-19-2008 05:05 AM
Gears for a Dana 44 obananna Chevy Truck Forum 4 08-08-2008 08:30 PM
dana 60 stearing knuckle seals....... charlie g Ford Truck Forum 1 01-02-2007 03:17 PM
Dana 70HD rear diff with 4:10 gears chevyguy Truck Classifieds 2 10-31-2006 11:09 PM
