Old 08-01-2009, 11:01 AM   #1
Banned
ErwinRommel will become famous soon enoughErwinRommel will become famous soon enough
1979 Ford F150 4X4 dash cluster problem
Well, my gauges seem like their not working like they should.
-My speedometer doesn't work.
-My alternator gauge works I guess because it moves and stuff.
-My oil pressure gauge works I reckon. It stays in the normal area but more toward the Low way but over the OR in Normal
-My gas needle moves very very slowly but only moves up to the E and no farther.
-My temp gauge works a little and moves up over time once the engine warms up but it take it a bit due to the engine is cool at first.
I need my speedometer working and my gas needle.
I wonder if the speedometer sensor is messed up.
I don't know what could be the gas needle problem...
What could be the problem?
ErwinRommel is offline   Reply With Quote
Old 08-01-2009, 11:26 AM   #2
Your speedo works off a gear and not a sensor. The cable goes to the transfer case and is held in with one 3/8" bolt. Remove this bolt and retainer and pull the cable out to inspect the gear. If the gear is bad then you must replace it. Chose the one with the same color as these are specific to vehicles. Different colors are available to compensate for different gear ratios or tire diameters.
If the gear looks fine then you must inspect the cable itself. If the cable has broken within the housing then you will have to replace the entire cable. Pulling on the speedo cable itself (the inner portion) can help determine whether or not its busted.
You must also make sure that the cable is plugged into the dash cluster itself. Be careful if you handle these old clusters. The white part is fragile and may break easily. Do some verificatoions of this before we discuss the replacement of the cluster. If you have to replace it, you will be looking for one out of an 80's van. More on that later should we find the need.
OK, the other gauges. Your gas gauge recieves small voltage through the sending unit, and you have to make sure that the wires are clean and not shorted anywhere.
You issue can be a couple of things, either a bad sending unit, or even a bad circuit board in the dash cluster. Since all of the gauges appear to have a problem then I may lean towards the fact that the printed curcuits in the cluster are going bad.
Old 08-01-2009, 11:33 AM   #3
Banned
What gear?
I know my tranny seems to not change like it should sometimes. I think. I think it may be slipping. But after it warms up....it changes good.
So I have to buy a new cluster eh?
Old 08-01-2009, 10:48 PM   #4
Banned
Well my temperature needle wire that goes to the water pump or whatever is messed up.
I just might not buy a cluster and just buy regular manual guages. Just keep the speedo though on the dash.
What do you think?
Old 08-06-2009, 12:12 PM   #5
Banned
Well finally pulled the cluster apart and the speedo cable is hooked up to the speedometer and I checked the gears in the transfer case for the speedo and it looked fine.
My guess is, is that the speedo part doesn't work no more.
I had to use an angle grinder to try to get the cluster off though because of a stupid rusted screw wouldn't come out!
HOW DO YOU TAKE THE CABLE AND STUFF OFF THE CLUSTER?!!!?!
My cluser is just hanging by wires now. Lol.
Old 08-09-2009, 08:38 PM   #6
Banned
Well I decided to buy me some manual gauges from Advance. Got the Temp, Oil and Volt meter.
My plans are to take out the original dash cover piece and make a custom dash cluster.
I want to put diamond plate across it and then install all my gauges. I think it would look bad ***. I think 75 has one in his yeller truck like that.
Old 09-23-2009, 12:24 PM   #7
rickahyatt is on a distinguished road
I, too, have that problem on my 81 F250 Ford Gas guage works but nothing else (To include reverse lights) Someone's rewired the **** out of it. But, mainly, I'd like to get the temp guage & speedo working. Have tried checking plastic gear, it's OK. New cable that will run the speedo with a drill attached. Can it possibly be wrong gear from dealer? If I put my finger in trans can turn metal gear. I also have a spark plug that apparently has a worn valve guide & always has to be replaced. Told to put in plug with wider gap, or just run hotter plugs. Good idea? (I never know how hot the engine is.)
rickahyatt is offline   Reply With Quote
Old 09-23-2009, 12:26 PM   #8
Oh, fixing truck because my Mazda 626 blew a head (Gasket?)
Do you have any faith in that new expensive sealant I've seen at the auto parts stores? Have to drain all coolant, etc.., put in & it gets hard as rock?
WANTED! 1979 Ford F150 TRUCK BED (SHORT)! ErwinRommel Truck Classifieds 0 07-18-2009 09:31 PM
1979 Ford F150 4X4 brake job ErwinRommel 4x4 trucks / off road 181 07-08-2009 07:13 PM
What size socket will fit on my 4WD axle on my 1979 Ford f150 4x4? ErwinRommel 4x4 trucks / off road 9 05-18-2009 05:12 PM
1979 Ford F150 4x4 steering ErwinRommel 4x4 trucks / off road 11 05-11-2009 11:25 AM
1979 Ford F150 4x4 ErwinRommel 4x4 trucks / off road 50 04-08-2009 12:33 AM
