Old 08-11-2009, 05:33 PM   #1
97tahoe trouble is on a distinguished road
Help 97 tahoe 4x4 trouble
My 97 tahoe has no power to the actuator on the front differental the transfer case engages and the front driveshaft turns but the hubs do not lock. The actuator is new but there is no power to it at any time. I pulled the actuator and manually lock the hubs with a bar so it has to be something between the transfer case and the front.
Any help will be great!!
thanks wes
97tahoe trouble is offline   Reply With Quote
Old 08-11-2009, 08:12 PM   #2
stumpuller454's Avatar
check the ball switch on top of the t-case, may be broken wire, or swithc has failed, if you remove the switch and push the ball in, it should send power to the actuator, have you also checked the 4wd fuse in the lh dash fuse box?
Old 08-12-2009, 08:10 AM   #3
chevyguy's Avatar
This is why i removed thst stuff adn went to a cable actuated system on my 93. Well till I went SAS anyway. Those actuators are known to fail. You want to know your 4 wheel drive is going to work when you need it to. Search for the cable actuator kit adn be done with that electronic actuator altogether.
USMC 92-96 USCG 98 to present
Old 08-12-2009, 03:50 PM   #4
if you do a search there are all kinds of procedure post on this from last winter
need some help in my TAHOE THE_DOC Chevy Truck Forum 1 06-11-2007 07:26 AM
Please Fix My Tahoe!!! dilli Chevy Truck Forum 26 04-09-2007 06:09 PM
Greetings From Tommy Tahoe tommytahoe Introductions 1 12-24-2006 12:53 PM
98 Tahoe For Sale 5,000 $$$ tommytahoe Truck Classifieds 0 12-21-2006 07:52 AM
99 chevy tahoe gortiz Chevy Truck Forum 0 02-03-2006 08:40 PM
