| | #11 |
| Banned Join Date: Jan 2009 Location: Southern Georgia
| Pick up the 4x4 rusted cab. Drag it out the way and then put the donor truck cab on. |
| | #12 | |
The rear leaf spring. It's thicker than that of the 2wd. Your probably right. I just thought it would be simple with the way I was talking about than tearing the engine out because I don't feel like hooking the brake booster and everything in the 2wd compartment. | |
| | #13 |
| started all those batched body swaps in the first place. There is always much more to a body swap than you think. Now, I swap out the drive train components unless it is a ground up restoration or from scratch build. Here is an example: The Dana 60 swap as begun Yes, I did buy a lot of stuff. But I could have easily done this with parts strictly from the donor truck.
| | #14 |
| Well the 2wd frame won't be tough like the 4wd frame. |
| | #15 |
| Why is that? What are the major differences?
| | #16 |
| Are you sure about that? I know that Dodge used to use heavier frames for their 4x4 Dakota's, but I'm not aware that Ford did that. Not saying they didn't, just that I have no info one way or the other.
| | #17 |
| That is the point I was making. When I did all those half ton conversions I did not notice any differemces. Where I use to live, it was eiser to find peices to a Ford 4x4 that an than an affordable complete one.
| | #18 |
| Senior Member Join Date: Aug 2009 Location: Ft.liqourdale, FL.
| I would personally swap the drivetrain instead of taking apart two trucks. half of your work is already with the two wheel drive. Be smart save yourself some work. Everything should bolt up. the other thing is are both trucks auto. or man. trans.? or are they different from each other?
__________________ ASHES TO ASHES, DUST TO DUST, IF IT WEREN'T FOR CHEVY'S MY TOOLS WOULD RUST |
| | #19 |
| I agree comepletely.
| | #20 |
| Both automatic. It's just where the transfer case is, it's bolted on this plate which the plate is bolted to the frame. Plus. I don't feel like taking out the brake boothers and unhooking everything. That would be aggervating. |
| Md: Feeler - 1989 truck part out (56K Beware) | JVEC | Toyota Truck Forum | 13 | 08-24-2009 02:59 PM |
| Chevy truck part | FIRSTTRUCK | Chevy Truck Forum | 4 | 03-28-2009 07:30 AM |
| Older Chevy Truck Part Dealers | josh29j | Chevy Truck Forum | 1 | 05-11-2008 07:25 AM |
| Part of N4 in Mpumalanga closed after truck overturns (SABC News) | trucknews | Truck News (headlines) | 0 | 04-28-2005 01:30 AM |
| Overturned Truck Closes Part Of Highway 70 (WRAL 5) | trucknews | Truck News (headlines) | 0 | 02-28-2005 07:30 AM |
