| I am wanting to lift my truck but can not decide what brand is better. I have been told RCD is good cause it keeps the same upper a arm in the stock location. I have been told skyjacker is good! and that fabtech is good also. All this has been told to me by salesmen trying to make a sale. So for the guys that actuall have lift and KNOW which is better, which brand of lift is good for a 92 GMC Yukon GT 4x4. I know I have only mentioned 3 brands cause those are the only ones that have been recommended to me by the shops. I am wanting a 6" lift if that changes the outcome. Thanks.
| Hello anyone in here.
| Senior Member Join Date: Aug 2009 Location: Ft.liqourdale, FL.
| My buddy had a 1996 gmc 1500 and the fabtech on his truck destroyed the front end. the cv axles were at two much of an angle so it kept wearing them out. we ended up taking the lift off of his truck.
__________________ ASHES TO ASHES, DUST TO DUST, IF IT WEREN'T FOR CHEVY'S MY TOOLS WOULD RUST |
| Ok good to know I hadn't really heard good things about fabtech on 4x4 was told they were good for 2x4s. Thanks.
| | #5 | |
![]() what size lift was installed?? | |
| | #6 | |
__________________ ENGINES PRODUCE POWER. MOTORS RECEIVE POWER.![]() https://lastroundbestround.com/Home_Page.html | |
| you can go just as tall as you want but other things should be thought of when you start getting that tall. 6in and above and you will need to redo the rear driveshaft angles otherwise, you will start going through u joints. as for the front end, 6 is alot for independant suspension and if you want something that is NOT going to rear up, look into a SAS. this will insure alot more reliability, plus alot more options when it comes to lifting. with this will sacrifice ride comfort though. |
| SAS? Solid Axle Suspension? Always had an issue with vocabulary.
| 6 is alot for independant suspension and if you want something that is NOT going to rear up, look into a SAS. this will insure alot more reliability, plus alot more options when it comes to lifting. with this will sacrifice ride comfort though.[/quote] I see what your saying i wasn't trying to bash fabtech. his truck had a 6" lift. I don't particularly like IFS four wheel drive i'm more of a straight axle kind of person. A SAS can be done they do make kits for it.
| SAS is a solid axle swap. getting away from the IFS and going to a solid front axle that takes much more abuse. |
| 2001 GMC 2wd Lift Kits(please help) | mbean50 | GMC Truck Forum | 3 | 02-09-2009 02:57 PM |
| 88-94 lift kits for sale? | hockeyhead89 | Chevy Truck Forum | 10 | 10-14-2008 12:50 PM |
| New 2007 vmax pros & cons | 07vmax | GMC Truck Forum | 0 | 07-20-2008 08:09 AM |
| lift kits | medic3616@sbcgl | Chevy Truck Forum | 12 | 09-26-2007 09:45 AM |
| 03 Sonoma Lift Kits | brent0702 | GMC Truck Forum | 0 | 08-28-2005 10:19 PM |
