Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 1997 K3500 4x4 stuck in the mud!
    Nov 2011
    16
    I'm new to the 4x4 world, and today after going to ranch and getting stuck was not fun! I'm determined to not have this happen to me again! I bought the truck two weeks ago and today I tried putting in in 4L nothing happen. It's manual on the floor with I assume it's auto locking hubs. When placed in either 4h or 4L the lights on the floor did not light up on the front axle!
    1. I checked fuse in door and checked good. Placed a new just be sure
    2. Checked fluid level was a little low but overall ok. (what king of fluid should I use in the front axle)
    3. ?
    This is where I'm lost. Could use any advice. I would appreciate the help! Tomorrow I'm off and would be a good day for me to work on it!
    Thanks,
    Nov 2011
    16
    Bump, thanks
    Moderator
    Jul 2011
    Central Oklahoma
    5,340
    1994 white ext cab chevy silverado 5.7 rolling 230k miles
    stock with air filter lid flipped,
    open flowing exhaust to a 40 series flowmaster dumped.
    God Bless America, Support our Troops!
    Nov 2011
    16
    Thanks, I just need help locating the Ball switch and transfer case switch.
    Moderator
    Jul 2011
    Central Oklahoma
    5,340
    Moderator
    Jul 2011
    Central Oklahoma
    5,340
    Alternative Discussion: 4X4 Wiring
    This one too talks about a time delay relay to engage 4x4 its under the hood, might see if you have something close to it. I just googled your truck 97 k3500 won't engage 4x4 and found these links.
  7. #7
    Nov 2011
    16
    After tomorrow I'll replace to actuator and then let you know! Cross your fingers for me
  8. #8
    Moderator
    Jul 2011
    Central Oklahoma
    5,340
    Before you replace it talk boards say take it off, engage 4x4 and see if it moves to make sure its bad before replacing.
  9. #9
    Nov 2011
    16
    I just remove it, keep it plugged in and have someone put the truck in neutral and switch it from 2h to 4l??
  10. #10
    Moderator
    Jul 2011
    Central Oklahoma
    5,340
    Should just turn key on move to 4wd and it should move the pin in or out, I also found this there is a fix for it a repair bulletin was issued for it, scroll down you will see the repair bulletin.
    98 K3500 Won't go into 4wd - ChevyTalk --The Social Network for Chevy Fans
  1. 85 k3500 w/454
    By gregd in forum GMC Truck Forum
    Last Post: 07-12-2011, 06:49 AM
  2. For Sale: 1997 Chevrolet K3500 Dually Extended Cab
    By NonGoggleGuy in forum Chevy Truck Forum
    Last Post: 11-17-2010, 07:01 PM
  3. 1997 GMC Sonoma key is stuck in the ignition?
    By mslitti in forum GMC Truck Forum
    Last Post: 04-24-2010, 10:46 AM
  4. 1997 Chevy K3500 4l80e transmission problem??
    By ABarnaby in forum Chevy Truck Forum
    Last Post: 04-21-2010, 07:01 PM
  5. 1997 Chevy K3500 T-Code & Vibration
    Last Post: 03-12-2009, 04:00 AM
