Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: 91 Chevy tbi 350 in a 85 CJ7 Crank no start
    Jan 2013
    10
    I put a 91 Chevy tbi 350 in my 85 Jeep CJ7. I'm using the painless wiring harness and can get the engine to crank but not start. I'm getting fuel but no spark. I have a new coil and distributor. I was told it could be the Vats system but don't think that that year truck had one. Any ideas?
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    are you getting 12 volts to positive side of ign coil?
    Jan 2013
    10
    Yes, I'm getting 12 volts to the positive side.
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    how old is the dist? sounds like control module may be bad. could also be rotor. remove coil wire from cap and hold just above coil wire post. have someone try to start it and see if it fires. if the coil fires i would say it is the rotor.
    Jan 2013
    10
    The distributor is new. I replaced it when I did the engine swap because the factory seemed to be in bad shape. I will try when I can get someone up to help me. Thanks.
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    if you still have the original dist. at least you've got some extra parts to try without buying more.
  7. #7
    Jan 2013
    10
    No spark from the coil post. Unfortunately I was unwise and got rid of the older parts while back. Lesson learned. So it could be the ESC module? Is there a way to get it checked before I put money into buying a new one. I bought a VATS bypass module that I have not installed yet because I don't think that is the problem. The guys at Painless told me that VaATS system could be causing the no start but I have read that it only turns off the fuel. I have also read that the VATS system did not come on tbi trucks.
  8. #8
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    yes the module inside dist. tells the coil when to fire. so really it could be the coil or module. i think most part stores can check coil or module to determine which one is bad.
  9. #9
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    Quote Originally Posted by Bigbobs View Post
    Measure the coil primary resistance. Using an ohmmeter, connect the red lead to the coil's positive (+) electrical connector, and the ohmmeter's black lead to the coil's negative (-) electrical connector. An average resistance reading could be between 0.3 and 1.0 ohms.
    7 Measure the coil secondary resistance. Connect the ohmmeter's black lead to the coil's negative (-) electrical connector and the ohmmeter's red lead to the coil's terminal-where the distributor or spark plug wire attaches to. A typical resistance reading could be 8,000 to 11,500 ohms.
    8
    Read more: How to Check an Ignition Coil | eHow.com How to Check an Ignition Coil | eHow.com .......... here is a link on how to check the coil if you have a ohm meter. need to isolate coil by taking the wiring from coil.
  10. #10
    Mar 2008
    N.Y.
    10,862
    Blog Entries
    1
    i think a hei ignition and carb would be the better way to go...bwai
  1. 93 chevy 1500 4.3 v6 flooding out. won't start. please help!
    By cperk89 in forum Chevy Truck Forum
    Last Post: 09-15-2010, 10:28 AM
  2. 91 toyota p/up crank no start
    By 1LowYota in forum Toyota Truck Forum
    Last Post: 06-07-2010, 02:23 PM
  3. Takes 5-6 cranks to start when cold...
    By 94Z71350 in forum Chevy Truck Forum
    Last Post: 02-18-2010, 12:45 AM
  4. 96 gmc k1500 crank, no start after engine swap
    By timsmothers in forum GMC Truck Forum
    Last Post: 12-20-2009, 11:25 PM
  5. dakota v-8 just quits running anytime,cranks no start
    By ubee in forum Dodge Truck Forum
    Last Post: 06-26-2007, 02:33 PM
