Old 08-05-2007, 02:32 PM   #1
Sneakysportsman's Avatar
Sneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to behold
Cruise speed missing
I am having missing problems at cruising speeds. I have done the following:
Changed plugs, wires, cap and rotor, Fuel filter, Checked MAP sensor, checked timing.
It dont miss at idle or while under load or hard acceleration, It happens during cruising and it is very noticeable in the exhaust tone. Any suggestions would be helpful.
Sneakysportsman is offline   Reply With Quote
Old 08-06-2007, 02:22 PM   #2
Check the cam position sensor. I've had one do that before and that was the fix.
Old 08-06-2007, 05:50 PM   #3
There is no cam sensor, its a 95 model, cam sensor came on 96 and up Vortecs
Old 08-06-2007, 07:57 PM   #4
ooppss.. my bad. Thought it was a vortec for some reason.
Old 08-06-2007, 08:06 PM   #5
Just has vortec heads. I am addressing a problem I had in another forum thread, that someone else is having and I think it might be my problem now.
Old 08-09-2007, 08:23 PM   #6
I have finally figured out the problem. Today I changed the plugs again, and this time i put them in the order they were removed from the block. Laid them on the table and went to crank the truck and again it was missing at throttle and cruising speeds. When I walked by the table I looked at the plugs and noticed a pattern. 1,7,4,6 all looked perfect. 2,8,3,5 all were gas fouled or burning rich. See the pattern? Injector on the driver side runs 2,8,3,5, these are the plugs that were bad. Problem- Injector firing too much fuel.
Old 08-09-2007, 09:05 PM   #7
Glad you got it figured out. I would of never though that.
Old 08-10-2007, 07:12 AM   #8
Moostang's Avatar
Now would that be a problem with the actual injectors or something else causing them to do that? I can't see all the injectors on one side going bad, I would think it was more computer related.. but of course I know nothing about Chevs..
Old 08-10-2007, 08:10 AM   #9
His is TBI. It only has 2 injectors.
Old 08-10-2007, 08:24 PM   #10
There were a few other things I founds out to day. The throttlebody is adapted to the intake, the intake is for a square bore carb, the guy who installed the adapter plate and flow matched all the internal surfaces didn't tighten the 4 bolts at each corner. Adapter plate to intake manifold gasket leak! next it had a serious backfire at on time, it blowed a metal reinforced gasket from under the TBI unit itself, another small problem. The back fire is caused from excessive timimg advance (28 degrees) is necessary for this cam. All these problems fell thru all at the same time, Coincidence or carelessness? I don't know.
3 speed automatic to 5 speed manual help torino Ford Truck Forum 12 02-25-2006 06:17 PM
Speed Channel Truck Stop: Todd Bodine Takes an RC Break (Speed TV) trucknews Truck News (headlines) 0 09-01-2005 09:30 AM
Speed Channel Truck Stop: Bill Lester (Speed TV) trucknews Truck News (headlines) 0 07-20-2005 01:30 PM
SPEED Channel Continues to be the Exclusive Home of the NASCAR Craftsman Truck Series (Speed TV) trucknews Truck News (headlines) 0 01-25-2005 09:30 PM
ASA Speed Truck Challenge Renewed for 2005 (Speed TV) trucknews Truck News (headlines) 0 12-15-2004 03:30 PM
