Register
Results 1 to 4 of 4
    19'78 Chevy saddle/dual tanks Wiring Harness
    I've been trying to locate a wiring harness fo a '78 Chevy half ton. It's the harness for saddle tanks with a black electric switch in the dash. I believe it was stock it was in it when I bought the truck. I'm just missin the harness. Does anybody know where I can find another one? Or at least a wiring diagram so I can hard wire it myself. Thanks for any help giving!!!!!
    Try this, I'm pretty sure it's the same set up. Check that nobody has modified your 6 port to a three or anyother thing like that. Many trucks with that set up had problems with the switch. Since it's not an on/off they usually disabled it and went with one tank. If yours has been cut free I suspect it was part of a problem. Hope this helps, good luck.
    http://s202.photobucket.com/albums/a...FuelWiring.jpg
    Attached Images Attached Images
    Please don't PM truck fix questions, bravely start a new thread for them. It is a forum afterall.
    Thanks for the schematic. That's what I've been looking for. It is a new switch and valve I just needed to wire it.
    Glad to be of help. Got help from others here, this is a little payback
    Surprised they couldn't give diagram with the parts.
    A little tip: a lot of the electric switches go in upside down to which wire is left or right to your eyes
    so check the power out before putting in dash.
    This is not on off but switching the hot and grnd with each other. if you do this with one tank full
    and the other empty it's easy to see on gas gauge which one you got.
    If tanks are same-ish or you can't tell, check power to sender for which is "on"
    Post back how it went, anything that hung you up, etc
  1. How Do I run a trailer light harness to the back of my truck?
    By bubbas91lariat in forum Ford Truck Forum
    Last Post: 08-04-2007, 07:42 AM
  2. 2001 Expy Overdrive Lockout Wiring Break
    By superluber in forum Ford Truck Forum
    Last Post: 05-16-2007, 05:12 PM
  3. Wiring question???
    By claytonfrnk in forum Chevy Truck Forum
    Last Post: 03-24-2007, 07:11 PM
  4. Towing wiring
    By TravelinSierra in forum GMC Truck Forum
    Last Post: 01-05-2007, 06:41 AM
  5. "99" Silverado harness diagram, anyone?
    By keith2441 in forum Chevy Truck Forum
    Last Post: 11-07-2006, 04:29 AM
Tags for this Thread
Back to Top
