| Junior Member Join Date: Aug 2007
| 1953 chevy wheel base Hi everyone: I am looking at a 1953 model 1019 series chev project that someone has lost intrest in he has it sitting on a 1986 standard 1500 series or c-10 pickup frame. there are no fenders on the front of the '53 and I am a little concerned that there might be too much difference in the wheelbase between the '86 the and the '53. I am told the wheelbase on the '86 is 117",does anyone know what the wheelbase is for the '53? Has anyone put one of these older trucks on a newer frame? thanks in advance Jim |
| welcome to the site; That would seem to be very easy to fix regardless of the difference, if any. I would imagine that the difference might not be exactly the same, but moving the rear axle is a snap. Simply line up the front wheel wells on the spindle centerline, and get the bed aligned. Then use a plumb bob fromt the rear wheel well center to aligne the rear axle. If you have to move it foward, then you can A: get longer leaf springs and move the front hanger foward enough to keep the axle centered under the wheel well. B: Use the same springs and just move both hangers to relocate the axle properly. By choosing the "B" option, this will aloow you to trim off any excess fram from the back of the trucks frame without changing any of the functional portion of the trucks frame. You will not sacrifice any strength this way, and is much better than taking a section of frame out of the middle like most "butchers" do. Should be pretty easy to do. Ride heigth can be altered while you are at it too. |
| True Chevy Lovers Help Me Please!!! Y Is Chevy Better Than Ford?! | chevygirl4life | Chevy Truck Forum | 81 | 03-09-2008 11:26 AM |
| 5.7 Chevy short block any difference? | KeckWerkes | Chevy Truck Forum | 3 | 08-11-2007 03:52 PM |
| Steering wheel | rednekracer | Chevy Truck Forum | 4 | 03-05-2007 09:12 AM |
| 92-99 K2500 wheel backspace question | Fortyfied | GMC Truck Forum | 3 | 07-21-2006 03:37 PM |
| 1989 chevy value | 396chevy | Chevy Truck Forum | 6 | 09-27-2005 10:23 PM |
