| Junior Member Join Date: Sep 2007
| New Member Need Help I am a new member and I have a problem I can't figure out. When driving down the road I hear a popping noise and then a high pitched whine. It feels like a brake is dragging slowing me down. I checked the front brakes and changed the rear drums. Everything looks good there. It will do it then quit then start back up again. I am getting ready to change the U joints. Any one have any other ideas? |
| Welcome to the site sheffie; We could use a little more information regarding your truck. Does this truck happen to have a 2 piece driveshaft? That noise could be the center support bearing. Can you determine where the noise is coming from? |
| I just pulled the front right tire off and I am pretty sure it is the wheel bearing. It is a 88 K2500 4X4. How hard is it to replace the front wheel bearing? |
| should only be a 15 minute job with air tools and a torque wrench. you may need a cold chisel and hammer to break the parts free due to rust. my hub cost me around $180, so make sure you found the problem before you throw that much money away.
| That solved the problem. Next is to change tie rods and ball joints then, hopefully I'll be done for a while. |
| new member in CT | TheZeidler | Introductions | 1 | 03-23-2007 10:21 AM |
| Truck Forum Member Promotions | Admin | News / Announcements | 0 | 11-05-2006 11:27 PM |
| New Member with ?????'s | Rodeo Bo | Introductions | 0 | 10-09-2006 04:43 AM |
| WTB Rear Third Member 89-96 Toyota P/U | BigRedToyota | Truck Classifieds | 0 | 08-08-2006 12:15 AM |
| New Member, 96 Ram 1500, 5.9 ci, 168,--- miles | Larry O'Daniel | Introductions | 1 | 07-07-2006 01:01 PM |
