Old 09-23-2007, 04:05 PM   #11
Hayden's Avatar
Check your fuel delivery. Change Filter. Maybe your pump is going bad and it takes a few minutes to loosen up a little and provide nominal flow.
Old 09-25-2007, 05:10 PM   #12
chevyguy's Avatar
First off Semper Fi devil dog 1992-1996
Secondly , it really screams EGR or vacuum leak to me. Try tohe old carb cleaner around in the engine compartment when its running and see if the idle speed changes.
USMC 92-96 USCG 98 to present
Old 10-25-2007, 07:43 PM   #13
Taco2aHD is on a distinguished road
check cold start injector i had same problem with my v6 toyota
05 1500hd lifted with intake and cat back hypertech programmer.
1991 toyota sr5 2wd ext cab v6
Taco2aHD is offline   Reply With Quote
Old 10-25-2007, 09:50 PM   #14
No cold start injector on a chevy... You should have a code if it`s running that bad. ck eng lite on??
Old 01-23-2008, 08:26 PM   #15
STRAYDOG is on a distinguished road
problem was resolved needed spark plug wires
Semper Fi
STRAYDOG is offline   Reply With Quote
Old 01-24-2008, 12:08 AM   #16
crabtruck's Avatar
Glad you posted that back and that it's fixed.
Did you find damage in wires or just take a blind shot and get lucky ?
Old 01-24-2008, 05:17 AM   #17
crabtruck >> it was a process of elimination & the plug wires had never been changed ( I am original owner ) .......... now my problem is trying to get tailgate cables off ( both broke) the rivet seems to need to be either cut with a dremmel or drilled out cant get off ( rivet holds cable to tailgat).. any experience with this ? thanks
Semper Fi
Old 01-24-2008, 02:44 PM   #18
crabtruck's Avatar
As is pretty common, both of my k1500 cables are snapped.
Luckily, for whenever I finally get to them, they are torx not rivet.
From what I've heard, drilling out the rivets and going back with screws
is the norm, and not that hard. Couple folks on here have done it for sure.
1988 Silverado k1500 z71 - runs great, for a few minutes. rkrizan Chevy Truck Forum 4 10-28-2009 03:04 PM
Running rough when cold nnunez Chevy Truck Forum 3 08-01-2007 06:57 AM
96 gmc suburban eng runs rough at times ninong GMC Truck Forum 0 06-28-2007 11:14 PM
1988 Silverado k1500 - runs great, for a few minutes. rkrizan Chevy Truck Forum 14 03-28-2007 06:20 PM
94 K1500 Runs Rough When Cold tdyer Chevy Truck Forum 0 04-07-2006 06:32 PM
