Old 09-12-2007, 09:37 AM   #1
1984heartbeat is on a distinguished road
decreasing rear brake
Is it possible to decrese the pressure to my rear drums on my 84 K10, they have a tendency to lock up with only moderate pedal pressure. Ive found my self in a few hair raising skids since i bought this truck.
Chevrolet. . . . . . The Heartbeat Of America!!!
1984heartbeat is offline   Reply With Quote
Old 09-12-2007, 10:22 AM   #2
That is a tension problem, and not a pressure problem. Drum brakes are adjustable, and are simply too tight causing the lock up.
Run the adjuster out so the shoes do not engage as hard, and your troubles will be over.
Old 09-13-2007, 07:31 AM   #3
where is the adjuster? Im not very firmilliar with drum brakes.
Also the Hames manual I have claimes it has self adjusting brakes.
Old 09-13-2007, 07:58 AM   #4
the "self adjust" to tighten but they will not loosen. On the back side of the backing plate at the bottom there should be a little rectangular hole. It might/might not have a little rubber stopper in it (to keep trash out) inside that hole will be an adjuster. looks like a big metal ring with little teeth on it. you can use a flat head screwdriver to turn but a brake spoon will work wonders and they are pretty cheap. IMO the best way to adjust is to jack the back wheels off the ground (with the front wheels chocked and jack stands for the back ) and tighten the adjuster till you feel drag, then loosen and stop as soon as the drag dissapears.
Old 09-13-2007, 05:03 PM   #5
436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold
your drums might be contaminated with either brake fluid or axle lube, that can cause a nasty lock up problem..
Joe
1962 Scout 80 parts I guess
1966 Scout 800 resto job
1996 P30, 6.5 NA Mac Mobile
whole lot of buicks
Old 09-13-2007, 08:28 PM   #6
that could be the case considering the age.
Old 09-15-2007, 03:36 AM   #7
My 57 Fird truck had the same problem it turned out to be the rear wheels cyclinder was leaking I replaced both and bought new shoes. My son is going to replace the rear brake shoes on the wifes van I told him push down on the hand brake four clicks then adjust the tension on the cable so that when you release the hand brake it adjusted just right you can also rebuilt the wheel cyclinders I have way back when I was dead broke well still broke but not as much.
Old 09-17-2007, 03:15 AM   #8
Are you sure you're getting suficient pressure to fronts ? "only moderate pedal pressure" is sort of relative...
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 22 06-24-2009 07:03 PM
Brake Dust Kawboy Ford Truck Forum 23 09-24-2007 02:04 PM
1949 3800 chevy panel brake dougmayer Chevy Truck Forum 2 08-22-2007 08:07 AM
Brake fluid tip chevyguy General Truck Forum 4 03-20-2007 07:43 AM
Chevy disc brake rear end 75K30 Truck Classifieds 5 08-17-2006 05:21 PM
