Old 09-17-2007, 07:03 AM   #1
1984heartbeat is on a distinguished road
Water Temp Gauge
95% of the time my water temp gauge works fine, but every once in a while the needle will start to jump around erraticly. after about 5 mins it works fine again. Is this a gauge or a sending unit problem?
Chevrolet. . . . . . The Heartbeat Of America!!!
1984heartbeat is offline   Reply With Quote
Old 09-17-2007, 07:56 AM   #2
could be either or. I would check the connnection at the sending unit first to see if it is loose and cuase bad/mixed signals, then follow it to the firewall and see if it has any bare spots where it can ground out.
Old 09-17-2007, 03:16 PM   #3
crabtruck's Avatar
I vote not the sender. And not the gauge. Stongly guessing the wiring connections. If not found there you could check the gauge socket itself.
Old 09-17-2007, 10:07 PM   #4
i vote wire problem also.
i had this problem with my tach for a few weeks until one of the coil wires came apart in my hands one day.
i'd rather be hunting
Old 09-18-2007, 07:41 AM   #5
I say having your water low in radiator will do the same thing it just happened to my nephews saturn not even the tech could figure it out till my nephew disconnected a hose and bleed the system I all started when the water pump was changed out but again you other members have a good points also.
Old 09-19-2007, 07:55 AM   #6
Im kinda startin to think it is a ground problem with the ground conection on the gauge. Ill tear the dash out sometime and clean everything up.
Old 09-26-2007, 11:44 AM   #7
The sending unit must make contact with water to work? Why would they install them on top of the engine?
Old 09-27-2007, 08:05 AM   #8
chevyguy's Avatar
i dont think its low collant, It takes too long to settle back in and work properly. i would chase the wire to start out.
USMC 92-96 USCG 98 to present
Erratic Temp gage??? MrBones Chevy Truck Forum 5 05-07-2007 07:30 PM
Non-functioning temp gauge C30 Dooley Chevy Truck Forum 7 03-24-2007 08:31 PM
Temp gauge Help claytonfrnk Chevy Truck Forum 2 03-16-2007 07:20 AM
Gauge Readings Bob Bradford Dodge Truck Forum 1 02-01-2007 09:37 AM
water temperture gauge question crazyhorse357 Chevy Truck Forum 6 08-07-2006 08:41 PM
