| Full Member Join Date: Aug 2007 Location: michigan
| lift kits I am considering putting a lift under my 95 K 1500, which would be a better choice a frame lift or suspension lift? |
| Are you asking about a "body lift" vs a suspenson lift? A quality suspension lift that is properly engineered to maintain factory steering geometry and driveline angles will be your best bet. How much you spend is up to you. This is a case where you get what you pay for. Spend a little expect little in return. |
| Senior Member Join Date: May 2007 Location: Florida
| ditto^^^. suspension lifts that are installed correctly are much better than body lifts.
__________________ ~Eric~ ɹǝʌo ǝɯ lloɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı |
| suspension is the way to go.
| Senior Member Join Date: Aug 2007
| I haven't had either, but I think you guys need to start explaining yourselves a little more. The body lift just lifts the body up off of the frame higher. A suspension lift lifts the whole frame up higher, instead of just the body. |
| Senior Member Join Date: Apr 2007 Location: Adrian, MI.
| It depends on what you are trying to accomplish with your lift kit. If all you want to do is fit some bigger tires under the truck, but don't really have the desire to go off road, you should go with a body lift, just because its cheaper. However, with a suspension lift, you not only get more clearance under the body and wheel wells, you get more clearance under the drive-train, steering assembly, and exhaust... basically the entire truck gets lifted off the ground except for the axles, and brake assemblies. The suspension lift rout will be a little pricier, but will allow harsher traveling conditions without expensive damage to vital parts like the engine, transmission, drive-shaft, and exhaust. Hope this helps |
| suspension is they way to go. and you can do it in a weekends time start friday night finish sometime sat. and to the tire shop for an alinement and trying it out sunday.
| is that wat you did?
| you live where the stores are open on sunday?
| yeah that's what i did i have 3" susp lift. and some stores are open sunday. mainly firestone because they have all the updated and new equipment but i have a life time alinement with them only cost $120.00 it's better than $50 to $80 everytime you need one. one time fee as long as you own it. but i get my tires else where lol cheaper
| too lift or not too lift, that is the ? | leviticusj2k | GMC Truck Forum | 4 | 01-17-2007 06:18 AM |
| Lift Questions | JenksBaseball | Dodge Truck Forum | 5 | 07-22-2006 10:04 PM |
| suspension lift | chevy kid | Chevy Truck Forum | 1 | 09-10-2005 08:30 PM |
| Suspension lift kits | RichardLGriffin | Ford Truck Forum | 5 | 09-06-2005 06:05 PM |
| 03 Sonoma Lift Kits | brent0702 | GMC Truck Forum | 0 | 08-28-2005 09:19 PM |
