| PO300 Code My 96 c10 just gave me a PO300 code biefly and when it was reset it hasnt come back on. This was the same code it gave me before I replaced a the cat.......at the time it also gave me PO420 (I believe). Well, my question is if there is a common problem in these vehicles that throw off the PO300 code. About 6k miles ago, I replaced ALL the ignition parts except the O2 sensor. |
| Senior Member Join Date: Apr 2007 Location: Adrian, MI.
| It sucks but I think you will have to replace the O2 sensors. I had the same problem about 1k ago. The only way around it was to actually FIX the problem. Retarded right? I know! Who would ever think that to get rid of a warning light, that you would actually have to fix the problem. It kinda sucks because my truck had 5 snsors and 4 of them needed replacing. Unfortunately, they were like $80 a piece.
__________________ "You can polish a piece of junk all you want, but in the end, all you're left with is shiny junk." |
| P0420 is cat efficiency code, so it may mean that the cat is losing effectiveness or an o2 sensor may be giving an off reading, but not so far off that it is completely gone
| Well, I replaced the Cat and the PO420 code is gone. All I am left is with the PO300 code. Is there a sparky in this forum that can tell me how to test the O2 sensor? |
| if you have a volt meter, you can hook it up and see if it is generating voltage... it should be constantly fluctuating, if it is before the cat it should be fluctuating very drastically, if after the cat it should be slower. the best way to test it is with an oscilloscope, but not many people have one of these kickin around
| | #6 | |
| I suppose I dont know how these sensors work. I was under the impression that they worked similar to thermocouples???? I can get my hands on an oscilloscope. Do you know what type of readings should we get? Why such fluctuating readings though? Quote:
| What engine is in your truck?
__________________ '93 Isuzu Amigo, Toyota Axles/Tcase/Drivelines, 35" MTR's. '01 Pathy, DD. ************************************** A fact of life: After Monday and Tuesday, even the calendar says W T F..... |
| Senior Member Join Date: Nov 2006
| what would the engine have 2 do with a cat related code?
__________________ Ride Til I Die |
| | #9 | |
__________________ '93 Isuzu Amigo, Toyota Axles/Tcase/Drivelines, 35" MTR's. '01 Pathy, DD. ************************************** A fact of life: After Monday and Tuesday, even the calendar says W T F..... | |
| It Is The 5.0, 1996, C10 - 97 Sierra - The Auto Part Stores Ask Engine Size When You Buy Brake Pads.........so Dont Be Surprised When Someone Asks For Engine Size To Do A Code Diagnosis.... |
| Trouble Code PO455 | cajunwoodrick | GMC Truck Forum | 10 | 07-05-2007 08:09 PM |
| Where Is The Door Lock Code | Lukka | Ford Truck Forum | 4 | 05-15-2007 05:45 PM |
| Code 42-Chevy 1500 | rockitman | Chevy Truck Forum | 1 | 06-01-2006 06:30 PM |
| code 43 nightmare | Deltadog | Chevy Truck Forum | 1 | 05-30-2006 02:37 AM |
| Code 54 | Slo 1 | Chevy Truck Forum | 3 | 11-24-2005 11:17 AM |
