Old 09-30-2007, 11:20 AM   #1
rednekracer is on a distinguished road
water leak
I have a coolant leak on left side of engine. It appears to be coming from the back of the cylinder head. I'm thinking it may be a head gasket. any other suggestions?
rednekracer is offline   Reply With Quote
Old 09-30-2007, 04:31 PM   #2
what year?
some were really bad about intake gaskets, and or the quick disconnect heater hose fitting in the intake.
Old 09-30-2007, 04:33 PM   #3
scottie's Avatar
pinpoint the leak and you should be able to tell where its coming from. hopefully its not leakin from a crack in the head
Old 09-30-2007, 09:39 PM   #4
I would first check the heater hose disconnect fitting at the intake like mrjohnwayne said if not do a pressure test. I don't think it's a cracked head not unless it overheated super bad it's going to be something small I bet.
Old 10-06-2007, 10:17 AM   #5
pscheers's Avatar
pscheers is an unknown quantity at this point
a good way to see if its a head gasket is look at your oil , if there is rad fluid in there then u know the issue , or check the exhaust for white smoke .....
pscheers is offline   Reply With Quote
Old 10-06-2007, 12:51 PM   #6
72'CaminoKid's Avatar
i'm with john and GMCtrucks on this one. ave had the quick disconect fitting problem on 2 differen chevy vehicles we have
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 10-07-2007, 04:00 AM   #7
On my 93 GMC that is one hose that I have never replaced I have it I just need to do it watch now it's going to start to leak just because I mentioned it. Let us know what goes with the leak?
Old 10-07-2007, 12:06 PM   #8
pscheers's Avatar
Isnt the heater hose fitting on the fire wall , and didnt he say it was at the back of the cylinder , i always thougth the heater hose runs into the front of the intake and water pump .. how would that be the probleum if its at the back ... does your intake block the back water ports on your cylinder head ?? my rpm performer does , i had a probleum before becasue of a leak there .. there is alot a clip that is sometimes installed into the passage way to allow heat to buil up .. ive only seen that on production intakes , most after markets just block it , , well my rpm does , not to sure about the rest .. try tighting the hose clamp on the fire wall ... my heater hose just slips over the copper pipe that leads to the heater element... ive only seen the disconnect added as a after market , not from the factory...good luck man
Old 10-07-2007, 01:49 PM   #9
It sure could be an intake gasket... I`ve seen lot`s of them leaking.
Old 10-10-2007, 07:07 PM   #10
It is a 95 Z71 with 5.7, I have replaced quick connect fitting allready but it is on RH side of engine. My leak is on LH side at rear of cylinder head. Thanks for the replies!!!
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 22 06-24-2009 08:03 PM
water leak in floor board watkins7871 Dodge Truck Forum 3 07-04-2008 07:58 PM
2007 Chevy A/C = water leak. Surf'n'Turf Chevy Truck Forum 1 06-04-2007 11:24 AM
water leak vincent tomaro Chevy Truck Forum 4 04-16-2007 07:21 PM
Got water mixing with crankcase oil. bigbassmann Dodge Truck Forum 5 03-01-2007 12:49 PM
