Old 09-30-2007, 01:59 PM   #1
thito01 is on a distinguished road
A Few Simplle Questions on 77
On my 77, the parking brake leaver does not come up to the top by itself. Is there originally a return spring on the leaver?
The factory water temp gauge has been disconnected. When I ground the wire under the hood, the gauge works. But, the wire is too short to reach the front of the block where the after-market gauge is attached. Where was the original water temperature sender located? (Please note that the engine most likely is not the original engine.)
There is a fuseable link block under the hood on the right side. (Plastic, 6 sided block, with two screw posts.) Does anyone have a source for a replacement?
Edit: Yes, I misspelled "simple" in the title. But, I don't see a way to fix it.
thito01 is offline   Reply With Quote
Old 09-30-2007, 04:36 PM   #2
I cannot remember if there is a spring for the parking brake or not.
the factory temp sender for the gauge is/was located on the driver side head between the 1st and second spark plug.
don't know what fusible link you are talking about.
Old 10-01-2007, 03:56 PM   #3
The Temperature sensor should be in the left head between the first two plugs. The parking brake should be pulled back with the cable. either the adjustment is out or the cables are seized. As far as the fusible link, napa sells generic ones that can be wired in. Although it sounds like your describing a junction block.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 10-03-2007, 08:28 PM   #4
97SierraStepSde's Avatar
97SierraStepSde is on a distinguished road
all foot controlled e-brakes have a return spring unless {edited by Dax} broke. haha this seems 2 be the case. not a big thing unless u use it often and are sick of manual return. Should be a replacement or a suitable substitute 4 it
Ride Til I Die
97SierraStepSde is offline   Reply With Quote
Old 10-04-2007, 06:55 PM   #5
chevyguy's Avatar
Aew we really allowing foul mouthed stuff here now???
i thought that was in the rules there turbo.
Yes you should have a spring, The temp sensor was already answered.
USMC 92-96 USCG 98 to present
Old 10-06-2007, 10:15 AM   #6
pscheers's Avatar
pscheers is an unknown quantity at this point
hey chevy guy , whats your probleum due , why do u have to go around startin **** allthe time ... i go t asuggestion to you man , try minding your own bussiness .. if thats possible , u might get along better ...
pscheers is offline   Reply With Quote
Old 10-11-2007, 06:23 PM   #7
pscheers's Avatar
i just want to say , that what i said was un called for , and i did write an appolgie..
Old 10-12-2007, 07:18 PM   #8
chevyguy's Avatar
He did , No harm man, Everyone has an off day. i dont take anything seriously
General questions about 1982 F100/150... jimfox Ford Truck Forum 4 03-07-2007 06:08 AM
Questions about my truck. elementzz456 Ford Truck Forum 2 12-23-2006 06:13 PM
91 chevy 4x4, lots of questions clpfiste Chevy Truck Forum 5 09-28-2006 09:56 AM
Questions, Huge engine havoc1336 Chevy Truck Forum 21 10-02-2005 05:57 PM
Canyon Questions trkman GMC Truck Forum 1 01-16-2005 11:37 AM
