Old 10-05-2007, 06:43 PM   #1
pscheers's Avatar
pscheers is an unknown quantity at this point
Help with transmission
Iam havin trouble again !!!! my transmiton seems to be gone ...but can still drive it ... when i put it in reverse today tons of smoke came from it , and there was fluid leakin that looked like burining plastic dripping off my passenger side exhaust pipe. I pulled out the dip stick , adn there was no fluid in the pan .... i ran my fingure down the the dip stick and the fluid was burnt , what does this mean??? I have another 700r4 to put into my truck , it is brand new .... but is the transmition in my truck have a electrical speedometer or a cable , pluse the transfer case output is on the passenger side on my new trans .... but i plan on putting a straigh axel conversion in soon , will it hurt things to run it without th edrive shaft hooked up??? i cant put it in 4x4 now casue every time i put th efuse in it ingages the servo on my front diff ...any help would be appericated
pscheers is offline   Reply With Quote
Old 10-05-2007, 06:59 PM   #2
You can run the truck without a front driveshaft, but we need to slow down. What t-case is behind the TH 700 that has a pass side drop? Did it come from an earlier model truck? Does it have the same length output for the rear, and is it the same as your current vehicle? Two types of outputs, slip yoke style, and fixed. They are not interchangable and will require shaft modifications.
As far as your SAS, which front axle are you going to run? A chevy / dodge, or a ford front axle? This should determine which t-case you are going to use.
Why not keep your existing t-case, and just use the new transmission? That would seem to be a reasonable solution that would solve all of your problems.
As far as the speedo goes, there are a couple of ways to go, you will have to determine exactly which style you have now.
Old 10-06-2007, 08:54 AM   #3
pscheers's Avatar
thanks again 75 k , i appericate al your help , if i can aquire half of what u know i will consider myself a accomplished mechanic ... i believe the trans behind my 700r4 is a np205 .. i dont know how to tell the diff ... see its in my other 1985 k 1500 ... its a reconditioned trany ..it has a slip yoke , i can just slip the drive shaft over the shaft....the other end is held in with 4 bolts and 2 bands .. i think i going to go with a chevy axel that way i dont have to much modification ....we were talking about this earlier ...here is the web site that has my kit http://www.offroaddirect.com/index.htm .. i have a 1989 k1500 chevy , see i wanted to use the 1985 axel as the doneer where it is lifted and beffed rite up ....im not sure what style the speedo is on my 1989 if its electronic or cable ... ??? can u shead any insight ..thanks for a ll your help
Old 10-06-2007, 09:33 AM   #4
Thank you for the kind words, awfull nice of you to say.
http://www.sky-manufacturing.com/
These guys have always done me right. I have no experience with the guys in your link. Looks nice though.
I do recall you were wanting to use the chevy front axle, and the chevy drop case. Should be no problem at all.
As far as the speed goes, you are gonna want to midify the gauges anyway. Did you know that Autometer gauges drop right in the openings of the stock chevy dash? They do, and it only takes a little work to do. The reason I recommend autometer, is because thay offer both style of output from your transmission. So if the new trans and 205 case is all together, you can simply throw that in and be done. Just figure out what style speedo it has, and buy the right speedo. It will be easy to do, and look really good. Later as money permits you can start upgrading all of them until you have a complete set.
There are also adapters available that will take a cable input and convert it to pulse if you need.
Heak it sounds like you have this thing ready to roll. Time to break out the gloves and plasma cutter. Better get the pizza guy on speed dial, and make sure the fridge has a few cold ones in it. I am getting excited about it as we speak.
In So. CA? I would be happy to lend a hand.
Old 10-06-2007, 10:00 AM   #5
J Long is on a distinguished road
My neighbor swaps rear ends on his 84 for one with a higher gear ratio when doing daily freeway commutes. He leaves the front axle alone but pulls the front drive line. He's been doing this for years but still wonders if he's hurting something. It would be interesting to hear just what he should worry about.
J Long is offline   Reply With Quote
Old 10-06-2007, 10:04 AM   #6
pscheers's Avatar
thanks man , i might just truck my truck down there to get your help ...lol .. im in new brunswick canada .... land of the moose ... thanks again man .. i was checkin out that web site and i noticed the pumpkin on the axel is located on the driver side.. if i am going with the axel out of my 1985 , where it is located on the passenger side will this affect the install of the kit on my truck??seein how the axel input for the drive shaft is on the passenger side??? I would love to have u wrench on my truck man , it would be an honer...in all truth i thnk there is way to much physicall distance..lol... Are u into hunting??? white tail deer season starts her in 2 weeks and i live on a 1500 acre daiy farm , with tons of 4x4 trails ..i want to build a offroad camp for people to come to , adn hold mudding comps , and rock climbing and so on ...in all i think 1250 acres are woodes land , so the deer her r really huge , dont allow to many people to hunt on my land .. me only ..i want to start a guided area wherei can guid u americans to the best hunting u have ever had ....but back to my truck , i have a couple auto meter gauges , i never knew i could install them into my dash , do they go in place of the old oil pressure gague , and volt meter ??? i am currently runnin my engine with no oil pressure gague , a big nono , i just have no place ot install my gague bank..??? so u think that this swap will go fairly easy?? another question , where my new transmition is a new re condition trany , how can i tell if it is working properly , before i install it ... i never bought th etranny myself it came with my 1985 truck when i bought it and the past owner told me it was new , but it has sit fo rabout 3 or 4 years since ...but i believe it is full of oil as well as the torque... i just want to make sure so i dont install something that is no good..thanks for the help agian
Old 10-06-2007, 11:19 AM   #7
Like a "shark suit", there is only one way to test that!
Afraid you are going to have to bolt it to an engine and drive it to determine its function. heak that is part of the fun, except when it does not work, then it is well,,,,not so fun, but hey it is still an experience.
Hunting, I used to be an avid hunter, and have been known to have a few moose steaks in the freezer. Elk and deer are my favorite, but I also enjoy hunting birds. Small game, but I do find my way up north to get a few duck and geese. suppose my favorite game bird is the pheasant. Smart fellas, and terribly tasty! I like you idea regarding the use of your land, just consider the liabilities that come with it. I was a small partner in an off road park, and it was a disaster. Talk about heavy a financial burdon. The insurances alone are enough to make a grown man cry. Oh yeah, these types of premiums are paid all at once, and you will need to have some pretty serious rules (and enforce them) to prevent any mishaps that may lead to a claim against said policy.
Enough of that, I like the idea. It sounds great, and I hope it works for you.
Yeah, the Autometer gauges can work in your existing bezel. The individual gagues that are 2 5/16" are a little bit large, but can be made to fit in the existing holes. There are several methods for mounting into existing holes. You just have to be creative.
Give me a few minutes to uncover my 57 chevy, and remove the steering wheel, and I will take a few pics of the gauges that I installed in the original holes. Came out as clean as any aftermarket set-up and still looks as though the factoery did it 50 years ago.
Old 10-06-2007, 11:48 AM   #8
pics of gauges
Here is the general idea. These are taken this morning. These are from my 1957 Chevy Bel Air 2 dr hard top. I have a fairly large engine in this, but it appears to be all stock. 4.88 rear gears with a super tight posi, a roller motor (big inch small block with aluminum heads) really get this big old car motivated. A little nitrous helps when I bite off more than I can chew.
Anyway, this is a generl idea of how aftermarket gauges can be installed into factory openings. It does not require that they have to look butchered up or hacked together. take your time, and they can come out fairly clean. Advantage is that it can be reversed if you want to go back to original.
Darn, files are too large. PM me for e-mail exchange and I wil send them to you.
Old 10-06-2007, 01:53 PM   #9
pscheers's Avatar
thanks , i will definatly appliy your thery to my truck , sounds like it will make a awsome addition ..i appericate the help ....
Chevy 3/4 ton Transmission shift problem OD issue fbhart@wk.net Chevy Truck Forum 2 09-23-2007 07:00 PM
E4od no shift ragtagf150 Ford Truck Forum 13 03-05-2007 09:06 PM
Transmission Problem z71chevy1996 Chevy Truck Forum 0 12-23-2006 04:05 PM
auto transmission won't shift and rpm& speed guages don't work gmcer GMC Truck Forum 13 05-04-2006 08:27 AM
Transmission Help Needed George911 Ford Truck Forum 7 08-02-2005 11:35 AM
