Old 10-10-2007, 05:00 PM   #1
peba's Avatar
peba is on a distinguished road
Torsion Bar
i have a 2004 chevrolet silverado z71 i want to adjust the torsion bar so it sits level do you recomend it and how do you adjust it.
peba is offline   Reply With Quote
Old 10-10-2007, 05:06 PM   #2
chevyguy's Avatar
Just turn the bolt under the key in a bit. You will need a front end alignment afterwards
Old 10-10-2007, 05:14 PM   #3
peba's Avatar
how much will it change i have alittle rubbing in the front
2004 silverado z71 exhaust, cold air intake, 32 mud tires , 8mm spark plug wires
Old 10-10-2007, 06:20 PM   #4
chevyman_03 is on a distinguished road
dont expect huge results... it shud lift it anywhere from about 1-3 inches... but be carefull, dont over do it
I'de rather PUSH a chevy... then DRIVE a ford.
chevyman_03 is offline   Reply With Quote
Old 10-10-2007, 10:28 PM   #5
97SierraStepSde's Avatar
97SierraStepSde is on a distinguished road
yeah ****in with the suspension like that I dont really like (along with spring drops and control arm drops aswell) is that u can only counteract so much with ur camber angles and what not. They just started making parts for like 88s-98s to fix what ppl have ****ed up with spring and control arm drops..as well as lifts. But good luck
Ride Til I Die
97SierraStepSde is offline   Reply With Quote
Old 10-11-2007, 01:39 PM   #6
tdyer is on a distinguished road
You will lose some suspension travel and ride quality. Front end alignment will be needed too, as mentioned above. Are you rubbing metal or the air dam? If it's the air dam, I'd trim it.
tdyer is offline   Reply With Quote
Old 10-11-2007, 03:16 PM   #7
chevyguy's Avatar
If tis rubbing , adjusting the torsion abrs wont help. It rubs in turns and the very little bit of lift it will give you wont be enough. You can trim the bumper corner and the fender rear corner , or just get a suspension lift and get soem real travel
First post; Torsion Bar crank on used 99 Silverado Chipster Chevy Truck Forum 2 07-24-2007 09:30 AM
torsion bar adjustment... yes or no?? chevyman_03 Chevy Truck Forum 5 07-09-2007 09:47 PM
Torsion Bar adjustment? JohnD Chevy Truck Forum 4 01-31-2007 11:20 AM
S10 4x4 Torsion Bar Removal matthews Chevy Truck Forum 1 08-02-2005 11:37 AM
Torsion bars and add a leaf 2 in front 2 1/2 rear? 98Z71 Chevy Truck Forum 0 11-13-2004 11:46 PM
