| 1994 Chevy Pickup I put a new blower motor in it a while back cause the old one was rattling etc... Before I installed the new one though, the bottom two speeds(four total speeds) were not working. I assumed it was due to the motor just going to ****. Guess I shouldn't assume. I was told it was a bad relay for the switch but for the life of me, I cannot find any relays. There is none under the hood and under the firewall there is a turn signal relay and another relay, which I don't know what it is but I changed it anyway. Didn't help. BTW, my truck is a 1994 Chevy 1/2 ton with a 6.5 Liter Turbo Diesel with an auto tranny. Any help in figuring this out would be appreciated. Thanks |
| Welcome to the forum Dennis Near the pedals you have a flasher for hazards and another for turn. On the cowl, engine side of firewall, you have a relay and fuse for fuel on upper right under cover with battery junction block, and a stop light relay on upper left above brake booster. ![]() Your three blower relays are under/behind the instr panel. They are interchangable so you can switch them to see if you get different speeds. You may have a bad resistor or maybe just loose / wrong connectors from before the recent swap. ![]() bigger view: http://i202.photobucket.com/albums/a...ter-ac-loc.jpg Hope this helps. Post back what you find. |
| I think what you're looking for would be the blower motor resistor, not relay..... Which is in the HVAC housing behind the glove box. If the blower works on speed settings 3 and 4, your low blower relay and high relay are both working. the low blower relay is used for 1, 2, and 3 speed settings. Hi blower relay is the bypass for 4. |
| Thanks guys. I will check this out Friday, my next day off. Appreciate the help. |
| 1970 Chevy C/10 Pickup | j3x | Truck Classifieds | 0 | 10-09-2007 12:43 PM |
| 1994 chevy 1500 cam swap | jag9177 | Chevy Truck Forum | 5 | 01-13-2007 07:41 PM |
| 1994 Chevy pickup electrical problems | seniorjudge | Chevy Truck Forum | 4 | 01-02-2007 08:17 AM |
| 1994 Chevy Fibrating | joshnkelly | Chevy Truck Forum | 4 | 12-30-2006 08:08 AM |
| 1946 chevy 1/2 ton pickup | 72'CaminoKid | General Truck Forum | 2 | 04-09-2006 06:50 PM |
