Old 10-20-2007, 06:18 PM   #1
046mag is on a distinguished road
Cool Steering Problems 76 Chevy short box
Just put 3/4 Ton running gear under my 76 Short box also put a 6" Rancho lift on as well. The 3/4 Ton running gear came off one of my other trucks I use too drive, It always wandered and I thought it was the steering box.
Put the running gear on my short box and it drives like my other truck did and a little worse. The truck will veer to the right out of the blue, and is just sloppy. I know I need new sway bar bushings, The ball Joints are good Drag link ends seem to be tight Could use a new steering stabaliser which i plan to get, Any thing else that could be wrong? It also has new tires, any suggestions would be cool.
046mag is offline   Reply With Quote
Old 10-20-2007, 07:00 PM   #2
These Chevy trucks usually rip the box right off of the frame. There are kits available to patch or fix the ripped frame, but I would take an educated guess and say that the steering box is falling out of the truck.
Now, that being said, since it apprears you are having the same problem with two different trucks, the common denominator is the axles. Now since you have a 6" lift, you can rule out the sway bars and bushings, throw them out, you will no longer need them.
Now I will ask you what type of steering correction you have done for the added lift. If you say none, or even have a drop pitman arm and still have the push / pull steering, then your biggest problem is going to be there. Willing to bet you truck makes very good turns one direction, but takes a country mile to turn the other.
Crossover steering is the only answer.
You could have a problem with the caster. If the kit you purchased came with "wedges" that get installed between the spring and axle pad to correct the pinion angle you may not have enough caster, and the axle is rolled too far foward. While this helps with pinion angle, it does bad things for the steering, and the steering becomes to fast to control, and feels twitchy. This could also explain the random wander.
Old 10-23-2007, 12:44 PM   #3
Streakn's Avatar
Streakn is on a distinguished road
The random wander can also come from the gear box, have you tightened up the worm gear?
3D graffix, as you can see by the spider, my graphics ain't from a piece of vinyl.
Streakn is offline   Reply With Quote
5.7 Chevy short block any difference? KeckWerkes Chevy Truck Forum 3 08-11-2007 04:52 PM
67 chevy 4x4 power steering goldengoat2 Chevy Truck Forum 2 05-07-2007 04:29 PM
2000 Chevy 4.8 5-speed 2wd Cranking Problems 06BLACKGMC Chevy Truck Forum 2 05-05-2007 04:27 AM
1994 Chevy pickup electrical problems seniorjudge Chevy Truck Forum 4 01-02-2007 08:17 AM
Power steering problems j_legos Chevy Truck Forum 3 03-27-2006 05:42 PM
