Old 10-24-2007, 09:16 AM   #1
What have I don is on a distinguished road
2004 security system dash light
I have a 2004 Silverado half-ton, extended cab z-71. It has the factory auto lock and alarm. Over the last 3 days I've noticed that the yellow security/alarm light on the left upper area of the instrument pod with a continuous, soft illumination, even when the ignition is off. It occassionally pulses, although this is barely perceptable. The lock/unlock and alarm features all work appropriately, with the suspect light brightly illuminating when the key fob buttons are pushed. The red radio LED also blinks appropriately.
Obviously, I'm worried about a short that could eventually drain the battery. I would'nt think this is a bulb problem, since power is getting to it even when the vehicle is not operational. Could it be a relay? If so, where is it? Is there a ground point for this? if so, where?
Any advice would be greatly appreciated!
Thanks
What have I don is offline   Reply With Quote
Old 10-27-2007, 07:28 PM   #2
NCroadracer's Avatar
NCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud of
sounds like the instrument cluster is the culprit. A complete lack of any security related symptoms and knowing the clusters for their sporratic failures... i'd say it's a safe assumption that the cluster is in its early stages of failing.
NCroadracer is offline   Reply With Quote
Removal of 1993 f350 dash bezel...how do i remove the light switch? PICS the_bay_mafia Ford Truck Forum 26 10-24-2007 09:13 AM
evap code on explorer scottie Ford Truck Forum 2 10-07-2007 01:04 PM
Dash Light on 1990 F-250 djdirtydavid Introductions 1 11-04-2006 08:21 PM
Weird one, headlights and dash light issue Koi_Boy Ford Truck Forum 5 04-24-2006 01:04 PM
Check Engine light and overdrive light on chief Introductions 0 02-05-2006 07:12 AM
