Old 11-01-2007, 11:05 AM   #1
pickupman2627 is on a distinguished road
88 chevy 350 TBI cuts out
hello, i have an 88 chevy silverado 350 TBI that will start up just fine, run for 5 to 10 seconds and then shut off (just like i turn the key off) it does not spit and sputter just shuts off. i replaced the cap, rotor and the electronic module under the cap. it stopped doing this for a few months, and now it started doing it again, it will not start up again unless i turn the key off, if i do it will start for the 5 to 10 seconds every time and turn off. i canhear the fuel pump pressure up every time. i have to turn the key off every time and it will fire for a few seconds, after doing this several times it will eventually take off and run great untill i shut it off with the key. then even when warm does not want to start up again.
i have called several mechanics and got a lot of puzzled faces, let me know if you have any ideas thanks!
pickupman2627 is offline   Reply With Quote
Old 11-01-2007, 11:18 AM   #2
do you have fire to the plugs?? have you tested the fuel pressure??
Old 11-01-2007, 11:33 AM   #3
Welcome to the site:
bradrhale made a great suggestion with regards to spark. have you verified that the spark is completely gone?
I had a coil go bad that did this same thing with voltage to it (key on). It would start up, and immediately turn off until i turned the key off and the ething cooled for a minute of two, then same thing. If I left the key on, no start at all.
I would check for spark after it tuns off without turning the key off and see if it is spark related. Should tell you just about everything you need to know.
Old 11-01-2007, 11:39 AM   #4
did thta model have the resistor that bumped voltage going to the coil? have seen those things crack a little and get erratic voltage readings. if no spark is present, start backwards and work your way towards the coil. saves on buying unnessary parts.
Old 11-03-2007, 10:18 PM   #5
brutis's Avatar
brutis is on a distinguished road
wouldn't it be in the fuel system ,cause if was spark when you restart it , it would back fire cause of all the fuel being pumped in there with no spark , so i think it's in the fuel pump relay etc.
brutis is offline   Reply With Quote
Old 11-06-2007, 11:24 AM   #6
chuckphillips will become famous soon enough
I have a intake and maybe the carb from a 88 GMC 350 if you need one. I took this stuff off to put old school intake/carb on my 69 vette I just sold.
chuckphillips is offline   Reply With Quote
Old 11-06-2007, 04:32 PM   #7
cplnorton is on a distinguished road
Mine did that and it was the fuel pump relay. It's a 13 dollar part at Advance/autozone. Might be worth a try.
Steve
cplnorton is offline   Reply With Quote
5.7 Chevy short block any difference? KeckWerkes Chevy Truck Forum 3 08-11-2007 04:52 PM
Question Chevy vs GMC Truck_Man General Truck Forum 63 04-16-2007 10:15 PM
Late Chevy truck wheels on early truck Unclejunk Chevy Truck Forum 1 01-08-2007 07:51 AM
1989 chevy value 396chevy Chevy Truck Forum 6 09-27-2005 11:23 PM
