Old 11-02-2007, 03:37 PM   #1
neon_boy82 is on a distinguished road
help!!!1996 Blazer no dash lights or fuel pump
Hi everyone. My neighbor has a 1996 4.3L Blazer and it won't start. When he turns the key it cranks but the fuel pump doesn't turn on and the only thing on the dash that works is the shift indicator lights, no check engine. battery, etc. If he jumps the eninge fuse in the panel to the one beside it the lights and the pump come on but it still won't start. Is it a shorted wire or a relay or what? Any help would be appreciated. Thanks.
neon_boy82 is offline   Reply With Quote
Old 11-02-2007, 04:00 PM   #2
scottie's Avatar
go through the fuses (dont "jump" any fuses, it could damage something) and check for any blown ones... there is also an inertia switch, that i beleive is in the cargo compartment that could have opened the circuit if he slammed the door or kicked it (it happens beleive me). id say check all fuses(under dash and in engine bay) make sure they all work.
Old 11-02-2007, 05:37 PM   #3
crabtruck's Avatar
Don't forget to check the fusible links to the junction block. What does work ? Blower, radio. turn sigs ? Welcome aboard.
Old 11-02-2007, 06:38 PM   #4
everything else works except the fuel pump and the idiot lights on the display. He doesn't have a repair manual so we couldn't find the fuse box or the fusible links under the hood. Also he said a couple days ago that it was taking a couple tries to start his truck so I'm guessing the pump wasn't coming on the first time.
Old 11-02-2007, 07:30 PM   #5
I`d check ror reference voltage out of the PCM to make sure it`s powered up and workiing... You should have a 5 volt reference or signal voltage to your F/I.. emmission sensors. (I usually use the throttle position sensor) There are three wires.. one of them sould have 5 vlts with the key on.
Old 11-04-2007, 06:21 PM   #6
okay all of the connections from the pcm were checked and they all had good voltage. He also repaced the fusible links and it still isn't working. Any new ideas?
Old 11-05-2007, 11:45 AM   #7
If you jumped the fuse and the fuel pump worked, then it could be the relay......
but why wouldnt the idiot lights work? They are not the same circuit?
Whatever it is, let us know when you find the solution.
Old 11-07-2007, 02:21 PM   #8
okay so the problem turned out to be the ignition switch. There was nothing wrong with the pump or the lights. When the key was turned on, all you could do was move the gear selector. There wasn't any power going to anything else.
Old 11-07-2007, 04:15 PM   #9
crabtruck's Avatar
Thanks for posting back the results, glad to here it's fixed.
As often as the key is a problem causer, we should probably think of it more often.
Can't tell you the number of times my truck wouldn't start until I found the keys.
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 11 10-28-2009 02:53 PM
94 Chevy K1500 Fuel Pump Voltage tdyer Chevy Truck Forum 2 10-15-2007 11:44 AM
Dash Ligts and Tail Lights out Motorcycle Nissan Truck Forum 0 04-05-2007 06:15 PM
1993 Crew Cab Dually- Fuel pump problem? RodrigoRodrigo Chevy Truck Forum 2 02-26-2007 05:27 PM
Fuel Pump will not turn on? cab41610 Chevy Truck Forum 7 07-17-2006 08:33 PM
