| Senior Member Join Date: Feb 2007
| power window help please on my 93 k1500 the drivers window just started acting up. the window will go down till about 2 inches from the bottom. then i will push the window down to have it completely open, but when i want to close it nothing happens, so i find out if i bang on the top part of the door where the window comes out the glass comes up and closes. any ideas? i would like to know what to look for before i take the panel off. thanks for all and any help. |
| Take the panel off anyways, a couple screws and clips. Look around for loose or pinched wires. switch could be bad. motor could be bad. window guides <-(dont know the correct term) could be bent. You need to get a visual on the problem.
| Full Member Join Date: Aug 2007 Location: michigan
| sounds like you may have a bad guide |
| thanks for all the info. will tackle it this weekrnd I hope. |
| Senior Member Join Date: Jun 2006 Location: Greenwood, Mississippi
| what did you find? I read your post concerning problems with the power windows, what did you find?, cause mine on my 93 G-20 van, are acting up as well. crazyhorse357
__________________ 1997 Lincoln Town Car 1993 Chevy G-20 conversion van |
| power window problems Thanks for the response, I replaced the double window switch on the driver's door and the passenger side window worked 2-3 times and quit again, going to pull the door panels off and conduct a visual inspection, maybe that will yeild some answers. crazyhorse357
__________________ 1997 Lincoln Town Car 1993 Chevy G-20 conversion van Last edited by crazyhorse357; 07-14-2008 at 11:46 AM. Reason: correct spelling errors |
| crazyhorse i would say your problem is the motor also. when they drawl to much power they will kill the switch and fast. if the bearings are bad in the motor then the coil may be touching the case and casing a massive draw. i would take the motor out and run 12 volts to it and try to see if you see alot of sparks. if you do then it is toast |
| Power Window Motor Replace | tucsonjwt | Chevy Truck Forum | 0 | 07-16-2007 06:37 AM |
| power window repair | Charlie390 | Dodge Truck Forum | 0 | 04-25-2007 06:59 AM |
| power window issue | JMP2204 | Chevy Truck Forum | 4 | 04-01-2007 07:23 PM |
| power window wont go down | atk | Chevy Truck Forum | 1 | 03-24-2007 05:53 PM |
| 85 E-150 Power Window and Lock problem | clev | Ford Truck Forum | 1 | 02-21-2007 06:22 PM |
