| Junior Member Join Date: Nov 2007
| brakes First I replaced my front brake pads then I drove it around it stops good. But then after I replaced the rear brake pads it doesnt stop as smooth it jerks when I slow down. Could the brakes be out of adjustment? |
| hard to tell what the problem could be without being there. did you do one side at a time and compare them when you were done?
| Welcome to the forum smooveshoezz. What kind of truck, year? Got any pics of brake work ? |
| Thanks its a 2002 chevy silverado.I didnt compare them after I finished.But I made sure I put everything back together right then I went for a test drive. I only noticed it after I did the rear pads. note the rear pads were worn all the way down to the metal. |
| check the drums. if they are scored then the brake pads could be threading on the drum causing the jerking. have the drums turned or replaced.
| replace rear rotors, practically all gm's those years need rotors |
| Junior Member Join Date: Nov 2007 Location: scottsburg, IN
| If I need to replace brakes, I usually have to replace rotors. Its just as cheap anymore to replace them, than to have them turned.
__________________ 4x4___3/4 ton chevy,TJ,Jimmy,Prarie |
| What brand or what type of rotor should I get or does it matter? |
| | #10 | ||
if the pedal does not pulsate then you can probably rule out rotors. i wouldn't want you to throw away a couple hundred on them and not need them.
__________________ i'd rather be hunting | ||
| 03 GMC Brakes HELP | Rene | Introductions | 2 | 11-12-2006 02:10 PM |
| brakes | rdnkmudder | Ford Truck Forum | 3 | 11-03-2006 03:04 PM |
| Brakes? | Beaver3000 | GMC Truck Forum | 6 | 09-03-2006 01:51 AM |
| ??brakes?? | tigman250 | Dodge Truck Forum | 12 | 07-29-2006 09:23 PM |
| brakes | scottie | Chevy Truck Forum | 3 | 07-15-2006 11:06 AM |
