Old 11-26-2007, 09:43 PM   #1
046mag is on a distinguished road
Question vibration
I have a 1976 chevy short box, recently built a 350 for it. bored .030 over,.050 lift cam flat top pistons, swirl ported 2.02 heads. Runs well, But has a vibration from about 2200 RPM to 2800 RPM. Vibration goes compleatly away with higher or lower RPMS.
Any Ideas to what is causeing this would be grartly appriciated.
Thanks
046mag is offline   Reply With Quote
Old 11-26-2007, 10:00 PM   #2
2200 to 2400 rpm huh? So this is rpm related, so the vibration is in the engine. What is the condition of the balancer?
Have seen the rubber in a harmanic balancer deteriorate and allow the balancer to slip causing all sorts of vibrations.
May also verify that you do not have an externally balanced flexplate on this thing.
Internally balance components only.
That would be my best guess.
Old 11-26-2007, 10:14 PM   #3
harmonic balancer looks good is tight canot wiggle or move it rubber seems to be holding tight. This truck has a four speed and the flywheel that is on it is correct not sure what is causeing it but very strange, you would thing if it was the harmonic balancer the vibration would grow exponentionaly as the RPMS increased
Old 11-26-2007, 10:36 PM   #4
Balancers can be funny, andnot always vibrate all of the time, well let ne re-phrase that, some vibrations that actually occur may not be felt, even though they are present.
So the balancer appears to be alright, and no problems. Are any of the pulleys bent?
What type of fan are you running? Could there be a problem there? Maybe a bent blade or something like that?
Old 11-26-2007, 10:48 PM   #5
as far as i know the pullys are alright, running a flex fan "noisy" will be comeing off soon. will check the pullys out tommorrow when i pull it in the shop. This vibration rattels the truck pretty good can feel it in the shifter hard to tell if it does it when driveing but can definatley feel when parked in neutral.
Old 11-26-2007, 11:03 PM   #6
I hope you find it. If it vibrates enough to rattle the truck a little, it can't be good on the crank, or bearings.
Gotta be in the rotating assembly.
You know, I was just thinking, I had a similar problem after a DYNO pull, and it turned out to be a crack in the water pump pulley. Could not see it very well, but it was there, and would allow the pulley to flex some causing a vibration.
94 Suburban Vibration cookcs Chevy Truck Forum 1 11-01-2006 01:42 PM
Skid plate vibration 3500hauler Chevy Truck Forum 2 08-28-2006 07:34 PM
Steering column vibration in 92 4x4 mochester Toyota Truck Forum 3 05-20-2006 11:27 PM
Engine Vibration Little Grub Chevy Truck Forum 4 01-27-2006 06:23 PM
New 2004 F250 Vibration gjakes Ford Truck Forum 2 01-15-2005 10:41 PM
