Old 12-02-2007, 02:07 PM   #1
cathunter is on a distinguished road
need advice on axles - cv boots
I have a 2000 chevy truck that I drive in the snow a lot. Problem is, I keep ruining cv boots (they freeze up) and causing axle problems. What are my options? Any after market axles that can be put on that don't have cv boots to freeze up?
cathunter is offline   Reply With Quote
Old 12-02-2007, 03:13 PM   #2
Welcome to the site;
How cold is it getting where you are at? The temps would have to drop so low that the engine may not run in order to freeze a CV boot. What are the other "problems" associated with this?
AM General has been using these boots for many years and they survive in some pretty extreme climates.
The same is true for the Mercedez/Uni-mog and several other military vehicles around the world. This has been the case for many many years. Imean the VW has been running a rubber boot since the beginning of time (or close to it)
Rubber seals are made from the same material, and they still do thier job in extremely cold climates.
Alright enough of that. To the root of the problem. While I admit that the cold climate could be a problem, I also believe that the boots you have installed may have other issues causing them to fail. If they are installed with too much tension on them they are working at full extension and this will contribute to premature failure.
Speaking of angle, how much angle is the joint itself working at? Have you added tension to the torsion bars? By chance is there a lift kit installed that is requires the CV to work at an extreme angle?
Old 12-02-2007, 06:32 PM   #3
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
Here in Buffalo I see alot of cold and snow, and never had a problem with cv boots failing. I have broken 2 CV shafts driving like a moron in the snow. Once the boot gets torn and the grease gets out, its just a matter of time before the joint fails. I agree with 75, something else is at play here. do you do a lot of plowing? or foot to the floor with the wheels at full **** driving?
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 12-02-2007, 08:43 PM   #4
No lift on the truck, factory suspension. I use the truck for work which requires going through a lot of deep snow and the snow packs around the cv boots and they come "unbanded". Or, if I don't clean out the snow, and park the truck for a bit, the snow will freeze around the boots and when I drive off will tear them. I just had a dealer replae them.
Axles Deltasigcj5 Chevy Truck Forum 2 05-14-2007 08:24 PM
I need some advice NateDog07 Ford Truck Forum 9 01-05-2006 09:01 AM
4wd axles bigowe Ford Truck Forum 0 04-28-2005 04:08 AM
Hired Truck boots out three more firms (Chicago Sun-Times) trucknews Truck News (headlines) 0 11-25-2004 03:30 AM
Dana Corporation Providing Axles and Driveshafts for General Motors 4x4 Medium-Duty Trucks (The Auto Channel) trucknews Truck News (headlines) 0 11-10-2004 01:30 AM
