| | #11 |
| Senior Member Join Date: Feb 2007 Location: Brandon,MS
| Well I just tried a couple things on wires to the fuse box and it`s not blowing now.Bad thing is,you just have to drive it around and wait to see if it blows.Just drove around for 15 minutes on the bumpiest roads I could find and it didnt blow.That doesnt mean much though,It may work for days before it decides to go again. |
| | #12 |
| You've been talking taillights, but you mean parking lights right ? Make sure you have checked the front lamps/sockets/connections. Any chance this happens with the turn signal on ? |
| | #13 |
| Tail lights,parking lights,driving lights.The lights that come on when you turn your headlights on.Not the brake lights.Brake lights and turn signals give me no problem.It`s never blown when I use the turn signal.When I`m driving at night it is completely dark on the back unless I use turn signal or hit brakes.The license plate lights dont work either when the fuse blows.I`ve checked those wires and they look fine. |
| | #14 |
| Yeah, I got which lights were on that circuit. That's why I was asking if you had checked the sockets/wires to front of the truck the same as you did to the rear. Gremlin has to be somewhere.... |
| | #15 |
| Junior Member Join Date: Dec 2007 Location: Missouri
| I had a similar problem with 97 that turned out to be a bulb that checked good..... |
| | #16 |
| found that sum beach.I decided to try changing out all my bulbs and when I was doing it the fuse started blowing while I was working on the front passenger side Followed the wire down from the parkink lights and found a little burnt spot.Cut it out,put a connector on and taped it up.That fixed it right up.Thanks for yalls help.Now its time to post about some other problems I`ve been haveing.
__________________ |
| | #17 |
| Is the dome light not on that same circuit???? Might check it. |
| | #18 |
| Its not on the same circuit on my truck.The light would still come on when I opened the door,But I fixed it.Thanks
| | #19 | |
Glad it is good now, and thanks for posting what you found. | |
| Running Lights Blowing Fuse | Austinr98 | Chevy Truck Forum | 0 | 07-10-2007 03:34 PM |
| Tail Light | Andrew14m | GMC Truck Forum | 0 | 02-19-2007 09:42 PM |
| chevy silverado 2500 hd fuse keeps blowing | outlaw7 | Chevy Truck Forum | 4 | 09-27-2006 11:11 PM |
| 89 Ranger tail light problems | dangerranger89 | Ford Truck Forum | 4 | 11-28-2005 02:55 PM |
| tail light burns out alot | 98Z71 | Chevy Truck Forum | 2 | 03-26-2005 08:45 PM |
