Old 12-06-2007, 03:50 PM   #1
ike77 is on a distinguished road
Question hard start when warm
I have a 02 chev 2500hd 4wd 6.0. has a hard time starting after its been driven and sat for a few minutes,will start fine if turned over right away. It seems like its not getting fuel. I have changed fuel filter and temp sensor and still have the problem. any thoughts or suggestions would be great.
ike77 is offline   Reply With Quote
Old 12-06-2007, 04:01 PM   #2
Welcome to the site ike77:
Has been a little while, but there was a 454 that had a difficult time starting and if I recall it turned out to be one or more injectors that had bad pintles and were leaking. This leaking caused a very difficult start situation when the vehicle was run and sat for a while. Now if it sat for a fairly long period of time, this fuel would no longer be present and the vehicle would start just fine. This gave a symptom of a hot start problem, and the symptoms had little to do with temp, and more to do with how long it took for an injector to leak off pressure.
May have the fuel pressure verified.
Old 12-07-2007, 12:41 AM   #3
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
replace your fuel pressure regulator, it's on the fuel rail with vacum hose on it, pull hose off smell/look for gas, very common problem, easy to change
jimbo543 is offline   Reply With Quote
Old 12-07-2007, 03:55 PM   #4
ryeja is on a distinguished road
Welcome ike77, 75K30 was referring to the problems I had with my 454(7.4l). I would advise the same and have the fuel pressure checked even before replacing the fuel pressure regulator. Could save you mucho denero replacing parts you don't need. I speak from experience. Good luck!!
ryeja is offline   Reply With Quote
Old 12-08-2007, 11:46 AM   #5
Problem solved! It was the fuel pressure regulater. Thanks for the info guys.
95 Dodge Diesel 12 valve Hard Start uscgret93 Dodge Truck Forum 5 09-21-2007 03:36 PM
1987 Silverado 350 TBI Auto., hard start, won't idle 87Silverado Chevy Truck Forum 8 07-08-2007 07:20 PM
7.3L hard start when cold wmiller Ford Truck Forum 9 06-02-2007 07:31 PM
truck wont start when warm redneck Ford Truck Forum 4 04-21-2007 06:16 AM
1990 chevy truck hard to start Bill Wiser Chevy Truck Forum 2 12-30-2006 08:18 PM
