Chevy Truck Forum - Chevrolet / Chevy trucks and their accessories forum. |
#2 (permalink) |
What type of truck are you working on? Is it just the button, or is it the whole switch? Some buttons are replaceable, and some can be removed with just a small screw.
The year of your ride is important. Might be the difference between an expensive 200 dollar switch, or a part that is less that 20 bucks. |
#3 (permalink) |
Moderator
96 w/5.7 4x4.
i wish i could help you, i just had my column apart last week. most likely will need a new combo switch.
proud member of the 200k mile club |
#4 (permalink) |
well if its a 95-98 chevy then have fun because i broke the one in my old 96 takin the dash bezel out and i spent like 140 at pepboys for the new switch which is the blinker, wiper, h-light dimmer, and hazard combo and it is a biznich to change because of where the harness on it plugs in under that dash, but it can be done.
#5 (permalink) |
Another thought if money/time/energy is short: pull the flasher.
Put back when you need it. May have to keep the switched jammed in with a toothpick. Only had one time where anything broke while near home. Lotta weird "fixes" |
#6 (permalink) |
I did pull the fuse to the flasher, but its also the fuse for the stoplights. So I have to keep it in. I jammed a folded piece of paper down in there to hold the button down for now. I have to replace the whole stick to get it fixed. The part alone is $150-$200.
#7 (permalink) |
Moderator
not the fuse. there should be a flasher either in the fuse center under the hood or under the steering colunm. it should be a round unit the size of a silver dollar. may disable the turn signal also.
| turn signal/hazard flasher relay location | basstracker | Mazda Truck Forum | 3 | 11-19-2007 08:04 PM |
| Push Button 4x4 | shorty27 | GMC Truck Forum | 7 | 01-29-2007 05:44 PM |
| Hazard flashers on 2000 3500. | rkn | Chevy Truck Forum | 3 | 07-29-2006 10:42 PM |
| Broken truck from Broken Bow (Jefferson City News Tribune) | trucknews | Truck News (headlines) | 0 | 05-17-2005 06:30 PM |
| Off-road hazard (The Robesonian) | trucknews | Truck News (headlines) | 0 | 04-29-2005 10:30 AM |
