| Full Member Join Date: Nov 2007
| clicking noise i have a 1996 k1500 350 5.7l vortec and a couple of weeks ago i went to push my dome override switch on the left side of the steering column and all the dome lights went on. then i went to turn the off and nothing happened. i could not get the lights to turn off so i eventually removed all the bulbs. then i drove for a little bit and all of a sudden i heard this rapid clicking noise from the direction of my switch and it sounded like the click when your blinker is on only is was more rapidly and only did it in like 2 second spurts. i checked all the fuses to see if one of them looked bad and nothing. i pushed the dome override button in again after a couple weeks of clicking and now i have not heard it since. i took the switch out and it looked normal however there were not wires that went to the dome override switch just to the dimmer control. if anyone has any ideas they would be greatly appreciated. thanks. |
| 96 with a dome overide??????? Not sure that is possible. Provided that you could get any relay to energize might indicate that you should consider problems with combination switch. I believe that most of the light circuits are directed through the light switch itself. I only question the dome overide, because my 96 tahoe does not have one, but my 2000 does. Regarless the switch may have aproblem. Last edited by 75K30; 12-19-2007 at 08:48 AM. |
| my 97 has an overide. although in never paid attention to the wiring during the numerous times i've had that side of the dash apart. |
| oops its a 1998 my old one was a 1996 |
| Senior Member Join Date: Jun 2007 Location: West Texas
| my 96 has a dome override switch. in the bottom left corener of the headlight switch pushes in and out |
| Full Member Join Date: Oct 2007 Location: Nanaimo BC Canada
| Could someone explain what a dome override is. |
| push the button in and it keeps the interior lights from coming on when the door is open. i only use it to save the battery when working on my interior and have to keep the door open. |
| Since my truck is too old to have that, I just use the "O.J.Simpson" lite. Probably nobody remembers, I know... |
| i think you enjoy confusing people don't you. lol |
| 1994 c1500 - clicking noise from heater | Chris | Chevy Truck Forum | 19 | 02-11-2009 06:10 AM |
| Lifter Noise | HUTCH | Dodge Truck Forum | 5 | 05-10-2007 07:56 AM |
| Clicking sound under driver's side console | nnunez | Chevy Truck Forum | 3 | 03-31-2007 06:24 AM |
| What Is That Noise? | Unclehose | Chevy Truck Forum | 3 | 11-22-2006 02:28 PM |
| 85 silverado clicking when key turned!! | mntman | Chevy Truck Forum | 3 | 03-02-2006 06:59 PM |
