Old 12-23-2007, 02:22 PM   #1
NCmau is on a distinguished road
Question Chevy Engine ID help
I am planning to restore a recently acquired 1969 Chevy truck. I have searched but I can not find out exactly what type of V8 engine is in this truck. The two sets of numbers located on left-hand side of the block, facing the cab, are 103070PB and 16B538136. This V8 is a replacement engine and It was rebuilt by a machine shop 14 years ago, Shortly after it was rebuilt, the truck was parked until I moved it. I would appreciate very much if someone can help me ID this engine. Thanks.
NCmau
NCmau is offline   Reply With Quote
Old 12-24-2007, 08:13 AM   #2
sorry, nothing comes up with those numbers.
i'd rather be hunting
Old 12-25-2007, 06:02 PM   #3
Chevy V-8 Engine Block and Head Casting Number Locations
May help a little.
Old 12-27-2007, 07:07 AM   #4
chuckphillips will become famous soon enough
NC, Find what you needed?
I recently purchased a 69 CST/10 with the original 396. I hope to have her on the Road by Spring.
chuckphillips is offline   Reply With Quote
Old 12-27-2007, 10:00 AM   #5
pit_boss is on a distinguished road
Heres another site you can check out..............................Chevymania!
pit_boss is offline   Reply With Quote
Old 12-28-2007, 09:27 AM   #6
NastyZ28 Second Generation Camaro Owners Group
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 01-26-2008, 09:19 PM   #7
stuvw2mny will become famous soon enough
I also had trouble identifying the 87 engine(i think) in my 77 truck. If you want to use the engine ID number, try Chevymania! or get a LMC Truck catalog (1-800-562-8782). This is the number stamped on a pad on the passenger side front of the block, and should probably have 3 letters at the end (known as the engine suffix code). If it doesn't have 3 letters it might be a very early block. The first letter of the id number identifies the manufacturing plant and the following numbers indicate a date. Since I have found differences in listings i would try at least 2 different sources for this identification.
For identification by casting numbers (raised numbers on the back of the block on the drivers side, I think, and on the heads) try www.jimsperformance.com/blocks.html or try a search for chev casting numbers.
Since you stated your engine was rebuilt, it may not match what the numbers say due to extreme interchanging of parts, but you have to start somewhere, I know. Good luck.
stuvw2mny is offline   Reply With Quote
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 22 06-24-2009 08:03 PM
chevy engine class? trcrawf3 Chevy Truck Forum 3 08-16-2007 10:11 AM
How best to remove 1972 Chevy 4x4 engine? rstricklin Chevy Truck Forum 3 08-27-2006 05:36 AM
2004 Chevy 2500 Needs New Engine SandChevy Chevy Truck Forum 2 04-08-2006 03:48 PM
88 chevy 350 engine swap???? fix_heli Chevy Truck Forum 2 12-01-2004 03:12 PM
