| Full Member Join Date: Dec 2007
| Does anyone know where to get a free detailed wiring diagram on the web for my 1972 Chevy Custom? I thank anybody for some info! Mel |
| i don't think your gonna find one bud.
| Ok. Thanks for the advice! I didn't think it could be that easy. Maybe you can answer a question for me... On my fuse block there is a bus fuse for the ignition(I'm assuming it's for the ignition). Does this fuse link to the distributor? If so, if the fuse is bad, could that keep the spark plugs from not firing? |
| i don't believe it goes to the dizzy, but i've never worked on that year. what is the fuse location labeled as?
| The fuse is labeled "ign". |
| if anything it is going to the coil, but not sure.
| I'll check it out and see if it will be a simple solution or not. Thanks man. |
| ![]() And the link for all the electrical you could ever want to know about for your ride good luck .http://www.autozone.com/az/cds/en_us...rInfoPages.htm |
| Mr. 75k30... Thank you much for that info. I've been searching for over a year and now my search is over. I'm sure things will go alot smoother now and once again, thanks. |
| 75 scores again LOL. Word of caution though mwalton, lots of drawings contain errors, some are radically wrong. More common in the generics. Use your head when reading them to be sure they make sense. But I do think it's better to have a drawing to correct than to have to start from scratch for most folks. |
| 99 F150XL 4.2, battery-relay-starter wiring diagram... | mlongue1 | Ford Truck Forum | 1 | 11-21-2007 07:55 PM |
| fuse diagram for 92 chevy | scottie | Chevy Truck Forum | 9 | 11-07-2006 06:18 PM |
| serpentine belt diagram for 1993 4.3 | crazyhorse357 | Chevy Truck Forum | 7 | 10-04-2006 05:29 PM |
| Pinoin diagram?? | Ford4x4Chik27 | Ford Truck Forum | 0 | 10-24-2005 12:26 PM |
| Wiring diagram Dodge Truck | HIGH TIMES | Dodge Truck Forum | 1 | 06-20-2005 09:16 AM |
