| Senior Member Join Date: Mar 2005 Location: ontario, canada
| antifreeze going down ? my antifreeze is going down and no leakes on the out side of the engine or heater. down 1 and a half litre in 3000 klm. could it be the lntake manifold ? any info ?? thank you ....pete
__________________ I am gm all the way ....... black 98 Z71 3 door short box 5.7 |
| If your losing AF and no leaks then it has to be internal. Is there white smoke coming out of your exhaust? Is your oil Milky? Can you smell it? Is your floor board saturated with it?
| what motor do you have? probably have a bad water pump..
| It says he has a black 98 Z71 with a 5.8l. Do they even make a 5.8? I know ford does but didn't think GM did. I might be wrong as usual though.
| antifreeze down thank you all for the info in 2004 i replaced the intake gaskets ...had a leak on the out side back drivers side may have to replace it again and it is a 5.7 sorry about that also how do i change that on my profile pete
| Go to user CP next to the home tab then go to edit profile on the left side of page. you can change it there
| i would put money on it that it's your intake. on gm's the back pass side mainly. use rtv black on the back of the block to the intake. and dont use a gasket there. or it will leak everytime.
| | #8 | |
| profile Quote:
thank you hayden have a happy new year ..........pete
__________________ I am gm all the way ....... black 98 Z71 3 door short box 5.7 | |
| I would bet on blown intake manifold gasket , my 2000 old style 3/4 ton with 350 engine has had almost everything possible go wrong with it. It was losing coolant, problem was intake manifold gasket, $400 solved problem at dealer. Talked to retired GM factory engineer, he said GM should have been made to recall 350 engine to replace intake gaskets. Problem started when they changed to orange antifreeze, this antifreeze was made for diesel engines and gas engine gaskets would not hold up. However, GM dealers made millions replacing gaskets on 350 engines as most went out after warr. Have a great Chevy truck day!!! |
| GM red antifreeze question | ohio larry | Chevy Truck Forum | 7 | 03-25-2006 08:26 PM |
