Old 12-31-2007, 02:20 PM   #1
chevy86 is on a distinguished road
TH400 issues
I own an `86 C20 Scottsdale pickup 2wd 3/4 ton. The TH400 automatic transmission shifts up through the gears until the truck warms up to normal operating temp. From there it will not shift into 3rd gear but stays in 2nd gear, unless I let off the gas and then you can feel it shift into 3rd. If I accelerate to gain momentum again, it goes right back into 2nd gear. I was told it was gummy/dirty inside the trans the last time it was serviced (about 2 months ago) another said an inside valving system that causes it to go to 3rd gear is somehow stuck or a valve-seal is torn, another said it's the governor. The modulator is good and has adequate vacuum. I also put about a quart and a half of "Trans-X" into it which I was told to use because Trans-X is very thin. Being a thin type of trans-additive, it was supposed to help clean things up in there. So far with no results though.
Ultimately I know I have 3rd gear just not after it's warmed up.
Any thoughts before I go through the expense of a rebuild?
thanks
Chevy86
chevy86 is offline   Reply With Quote
Old 01-02-2008, 11:29 AM   #2
My guess is that the guy who mentioned the seals is right. I would think that the servo seals are probably worn. Before I would go for a rebuild I would drop the oil pan, clean or replace the filter, refit oil pan and fill with new fluid along with a bottle of Lucas Auto Trans Conditioner. I use Lucas every time I do a trans fluid change. It may just get you another year or two.
Old 01-03-2008, 06:25 AM   #3
I will look into the Lucas product. Obviously something thin in the way of a "cleaner oil" didn't or hasn't yet done the trick. Concerning the servo seals, are they something within reach once the pan is dropped???
Old 01-03-2008, 11:20 AM   #4
Dropping the oil pan only lets you clean the pan and filter, you will not be able to access the clutch servo seals. However the Lucas product may soften and expand them. It is not that difficult to do and will only cost you the new fluid and and the Lucas, so worth a try. Should take less than an hour. If you intend to keep the truck for a lot more years or will be doing a lot of towing maybe you should consider a trans rebuild. It`s your call but like I said, if it was me, I would try the Lucas.
Old 01-03-2008, 06:03 PM   #5
phattysGMC is on a distinguished road
the same thing happened to my 86 when my son drove it on the highway it had 100,000 plus miles on it he didnt realize it didnt shift and BOOM the cam snapped so i put a new motor in and built the trans. i put it up on stands to make sure it shifted and it only had 2 gears checked pressures and were ok dropped the pan a million times couldnt figure it out was ready to pull it out and go thru it again had a friend w a tranny on the floor and i stole the valve body and swapped it and it was fine found one of the valves was stuck hope this helps
phattysGMC is offline   Reply With Quote
Old 01-03-2008, 08:40 PM   #6
1979_4x4_Plow's Avatar
1979_4x4_Plow is on a distinguished road
reminds me....i need to do a tune up and a trans filter kit on the truck. if anything i know it needs the tuneup. i am planning on doing a trans filter kit to see if it will help the trans since it quit on me last winter but i went to move it this year and it acted fine so far.
1979_4x4_Plow is offline   Reply With Quote
Old 01-08-2008, 07:57 PM   #7
I'll have to agree. either a stuck valve in the valve body or a torn/wore out seal for the 3rd gear servo
Heater issues karl66 GMC Truck Forum 1 05-23-2007 11:57 AM
abs issues HVY84CHVY GMC Truck Forum 5 01-02-2007 10:24 AM
Door Sag Issues? Mr. Thomas Truck Classifieds 0 09-27-2006 01:12 AM
A C issues mikerike Chevy Truck Forum 9 07-24-2006 06:46 AM
turbo 350 to th400 swap driller1720 Chevy Truck Forum 7 03-02-2005 07:25 AM
