| Junior Member Join Date: Dec 2007
| I have been having trouble with the fuel pump regulator located under the hood usually I just have to wiggle it around and the fuel pump will work.Today I tried that and I seen a little spark come out by one of the fuses. Got back in the truck and the fuel gage was stuck pass full and the truck will not start. I put a new fuel pump regulator in it with no luck. |
| did you make sure all your fuzes were ok? and it sounds like your cluster or inst. panel is going out common for gm products
| I guess you are talking about the fuel pump relay and you probably have a poor pin fit on the relay from high resistance in the fuel pump and you blew a fuse I think it is labeled ecmb fuse |
| 94 Chevy K1500 Fuel Pump Voltage | tdyer | Chevy Truck Forum | 2 | 10-15-2007 10:44 AM |
| 4.3L W code fuel pressure regulator | bodean | Chevy Truck Forum | 4 | 10-14-2007 09:09 AM |
| Fuel Pressure Regulator | nnunez | Chevy Truck Forum | 12 | 07-03-2007 04:41 PM |
| something killing my fuel pump 97 chevy 1500 | texasjack | Chevy Truck Forum | 1 | 03-18-2007 10:40 AM |
| 1998 V6 chevy S10 fuel pressure regulator diagnosis | STRAYDOG | Chevy Truck Forum | 0 | 10-21-2006 08:18 AM |
