| Junior Member Join Date: Jan 2008
| 03 chevy truck runs 2 seconds and then dies I have a 2003 chevy silverado 4.3L. It died driving down the road. Now it will start and run for 2 seconds then it dies. I have tried to scan it for codes. But it will not make a connection. I have reset the passlock. and reflashed the comp. The scanner still has no connection. |
| Put a fuel pressure gauge on it and see what the reading is when you turn your key to on.(don't start it).
| fuel pressure It has 58 lbs. of pressure. it does not lose fuel pressure when it dies Last edited by slim; 01-06-2008 at 04:26 PM. |
| Senior Member Join Date: Dec 2007 Location: Alberta
| that is way to much fuel pressure! this can cause just as much a problem as not enough pressure! its probly flooding your truck! may need to purchase a new pump! they have an internal regulator, but check for power at the pump, may be getting too much somehow, also check your ground, |
| not sure but i think the newer trucks require that much pressure. i think there is a cam sensor or something that deals with the fuel pump once the engine is started. maybe the oil pressure sensor.
| Yeah I agree with Mud, 58psi is about normal, I can't think of anything that'd shut down that quick to kill your engine. Can you start it right back up after it dies?
| Yes it starts everytime. |
| mr 75 could probably tell you but he seems to be on vacation, lucky anyways, i'm pretty sure it has something to do with your oil pressure sensor. i think if the newer trucks do not sense oil pressure it cuts power to the pump in an atempt to save the engine. might want to give the dealership a ring and try to confirm this idea.
| i dont know if 03 has a built in security system on it ,but on the 98 if the fuse is either pulled or blown it'll run for a few seconds then die.starts right back up runs for 2-3 secs. and dies again. |
| i bet it is the crank sensor. the engine turns over and starts running, and the PCM waits 2 seconds to receive the input from the crank sensor. if it doesnt receive the signal, it shuts the fuel pump off after 2 seconds.
| 98 S10 V6 Runs rough when cold after 5 miles runs great? | STRAYDOG | Chevy Truck Forum | 17 | 01-24-2008 02:44 PM |
| 95 dies then runs ok for weeks | Monteone | GMC Truck Forum | 10 | 08-21-2007 02:52 PM |
| truck runs rough | chrisjordan | Chevy Truck Forum | 4 | 04-04-2007 03:59 PM |
| chevy truck dies when hot - won't restart | chevyman1 | Chevy Truck Forum | 4 | 07-14-2006 09:16 PM |
| Man dies when van runs off road (Brisbane Courier Mail) | trucknews | Truck News (headlines) | 0 | 08-24-2005 03:30 PM |
