Old 01-11-2008, 06:11 AM   #1
STRAYDOG is on a distinguished road
HELP S10 4.3 installing water pump , cant get water pump fan off
Installing water pump on my 98 S10 V6,
how do you remove engine fan ? its threaded on the water pump shaft , cant turn nut hopefully not reverse threads , when fan off will there be enough room to remove pump ? do I have to remove radiater to access ?..... cant get clearance to get pump assy off......... any tips apreciated , thanks
Semper Fi
STRAYDOG is offline   Reply With Quote
Old 01-11-2008, 09:29 AM   #2
Stirgen is on a distinguished road
I had the same problem
with my 1996 4.3 L. I tried everything and finally just removed the water pump and fan as a single unit. Rather than just taking the fan off.
Stirgen is offline   Reply With Quote
Old 01-11-2008, 10:02 AM   #3
did you have to remove radater ? my 1998 S1O has little room
Semper Fi
Old 01-11-2008, 05:56 PM   #4
Snap-on makes a **** of a tool for the job. its designed to be used with an air hammer. works very well.
but its possible to do it without it. The belt needs to be on to hold the pulley. Then take a long crescent wrench, or pipe wrench and whack it hard with a hammer to shock it off. the wrench needs to be longer then the fan blades. It usually comes off after 5 hits or so. if you want to get fancy, I think its a 36mm nut, you could by the wrench..
definitly not reverse threads..
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 01-11-2008, 06:02 PM   #5
o3shortbed's Avatar
i would wedge a screwdriver in the bolts that hold on the pully(you may hafta unscrew the some) then use a wrench to take off the fan. that works for me. buy the way they are normal right hand threads.
Old 01-12-2008, 09:09 AM   #6
To all >>Thanks for all the info , I was able to remove the fan from the water pump & with the fan assembly ( fan/clutch ) off there was enough room to get the pump out with out removing the raditer.................. Job is done
Amendum I am the original owner of this 1998 S10 , for just about 10 years ...the water pump lasted 10 years >>> so whos to complain & still has the original exhaust system ........... life is good.........
" Semper Fi " & thanks..........
Semper Fi
Old 01-12-2008, 01:26 PM   #7
rdillon's Avatar
rdillon is on a distinguished road
You need a air chisel . Make sure your belt is tight. Look at the pitch of your fan blade. Simply opposite of crank direction. Press down on the chisel on the opposite way on that side of the nut. I do this all the time works well.
You can also take off the belt and use a long belt strap around the pulley and try to break it that way too with wrench the opposite way.
2005 Chevy 4x4 LS 5.3L BFG KO's
Sucks gas but hauls a**
1985 F150 5.0L EFI
Old and slow. Used as a decoy when parked at work 2 weeks at a time... Really not a bad truck 16 mpg
rdillon is offline   Reply With Quote
Why two gaskets for a water pump? gerryl98 Chevy Truck Forum 4 01-01-2008 08:54 PM
water pump jktuck GMC Truck Forum 10 06-23-2007 04:27 PM
Trouble with a water pump geauxstros Chevy Truck Forum 3 05-24-2007 02:32 AM
How do you change a water pump chafuro786 Ford Truck Forum 2 03-07-2007 10:09 PM
02 Silverado water pump. Kevin Hod Chevy Truck Forum 9 12-07-2005 07:20 PM
