| | #21 | |
sounds alright. quite some bullsh!t to take apart. since i had my top end apart i put in new injectors as well. little poppet hoses got hard and were starting to crack and leak. being it's all sealed it's quite a chore to take apart again to replace. since i had so many miles; 160,000, it was nearly 1/2 again due for a 2nd set in the first place. chrylers multiport design, injectors are out in the open and sit just before the intake valve. 4 bolts, 2 on each side holes the rails down ; but only bad part is the're exposed so, when you pull them out, dirt and stuff falls down into the intake. no big deal, just a surprise when a intake valve gets hung open and POOF goes the eyebrows. both have their pros and cons. ford uses similar design as chrysler. i think.
__________________ 1996 Z71 white shortbox tinted 350 30 over cats and X pipe Alumhds ported 210 cc runners 62 cc chambers 2" int 1.550" ex crane lift; 580/580 duration; 216/222 4L60E w/shiftkit Last edited by jdfenske; 02-03-2008 at 06:17 PM. | |
| | #22 |
| Junior Member Join Date: Apr 2009
| coolant Loss, 350 hi, my 2000 3500 had the same fault. I was using a jug every couple of thousand miles. You can smell the leak because its external. The parts guys at GM put me onto this fix. There are 2 main coolant troubles with these trucks. The intake manifold, and the quick disconnect fitting at the front passenger side of the intake manifold. It goes to one of the heater cord hoses, so its easy to locate. Its more or less behind the alternator. The old ones are pot metal. They corrode and start to leak when hot. The coolant evaporates when it hits the exhaust manifold, so its hard to spot. The new ones are $35 CAD and made of steel. I was warned to be very gentle removing the old fitting, as they are know to snap off in the intake manifold, then the whole manifold has to come off. |
| | #23 |
| welcome to the forum since the post is a YEAR old I would think it is fixed by now!
| | #24 |
| im so proud of you leo. although, i think hotrod has picked up some of your old habits. only he is doing it on purpose. |
| | #25 |
| that's ok it keeps mud busy closing them ![]() ![]()
| Tags |
| coolant, cooling system |
| Low coolant | stelmadl | Chevy Truck Forum | 14 | 03-15-2009 08:18 AM |
| Oil in my coolant | dhashigu | Chevy Truck Forum | 15 | 08-07-2007 02:29 PM |
| Diesel losing Power | GMC Smiley | Chevy Truck Forum | 2 | 02-15-2007 06:15 PM |
| Diesel Losing power | GMC Smiley | GMC Truck Forum | 0 | 02-14-2007 06:02 PM |
| When Life Is a Losing Streak, Remember the Red Sox (New York Times) | trucknews | Truck News (headlines) | 0 | 01-02-2005 11:30 PM |
