Old 01-21-2008, 03:01 PM   #1
Bama2008 is on a distinguished road
86 S10 carb injector problems
I have a 86 model S10 with the small v6 engine, the fuel injectors over the carb. the one on the right facing the engine sprays fuel, the one on the left doesn't, sometimes, I have hunted wire shorts etc.. Any suggestion would be greatly appreciated.
Thanks
Bama2008 is offline   Reply With Quote
Old 01-21-2008, 03:10 PM   #2
junior3382's Avatar
I could be wrong, but if I remember correctly, the second one does not begin to spray until you need it. like quicker accelerations or passing on the freeway, it will dump more fuel under certain conditions. Otherwise, you would be using more then you need. At least that was how the carb injectors worked on my 84 olds I had. Are you having problems in the way the motor runs?
Old 01-21-2008, 09:18 PM   #3
just swap the injector connectors and you will know if is abad injector or the wiring
Old 01-22-2008, 06:34 AM   #4
when idling if both don't inject the engine skips very bad, the same happens when you go down the road
Thanks
Old 01-22-2008, 06:36 AM   #5
I will swap this weekend and try, what to do if the problem moves?
Old 01-22-2008, 05:48 PM   #6
They should both fire. an old shade tree trick would be to wire them off of one side. then they would both fire and the truck wouldn't skip a beat, assuming of course the problem is a bad wire, not a bad injector.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Injector Problems - Help TxToyMan Dodge Truck Forum 2 07-15-2007 01:31 PM
Only one fuel injector, um, injecting. my350tpi Chevy Truck Forum 4 10-03-2006 07:11 AM
95 Nissan 4X4 injector problem cturner41314 Nissan Truck Forum 1 07-31-2006 01:31 AM
Injector goo please help!!! Trip next week jkluesner Chevy Truck Forum 4 07-14-2006 08:39 PM
carb problems F150on40's Ford Truck Forum 3 01-05-2005 07:52 PM
